16X9.5 or 17X9.5 wheels all around
Old 03-07-2008, 01:10 PM
68L71
68L71's Avatar
Default 16X9.5 or 17X9.5 wheels all around
I am going to be buying wheels for my 68 and have been trying to decide on the wheel size I want to go with. I like the 17 18 combo, but I also like the bigger sidewalls on the 16 or 17 inch wheels. I have heard people run 9.5 wheels with 4.5 backspacing all around. Would it be possible 16X9.5 with a 55 series tire or a 17X9.5 with a 50 series tire?
Old 03-07-2008, 02:36 PM
DRIVESHAFT
DRIVESHAFT's Avatar
Why are you determined to run different rim sizes?
Old 03-07-2008, 02:41 PM
gkull
gkull's Avatar
Received 1,331 Likes on 1,059 Posts
My front street tires are mounted on 4 inch BS 9X17 I have used the taller KDW 255/50/17 Right now I saved some $$ and mounted the 255/45/17 Kumho MX
4.5 BS and tall tires puts the sidewall into the frame on lock to lock.
I did mount some Goodyear F-1's on the rear years ago and they were something like 285/40/17. Nice diameter for the rear, just not enough tread on the ground
Old 03-07-2008, 02:49 PM
68L71
68L71's Avatar
I do not want to run different wheel sizes, I want 16 or 17 inch wheels, not a combo of both. I want to run torq thrust II’s and they only make 17X9.5 with the correct lug spacing, not 16X9.5.
So I am basically wondering if it is possible to run 17x9.5 (4.5” BS) on the front with a 50 series tire?
Old 03-07-2008, 02:57 PM
68L71
68L71's Avatar
[QUOTE=gkull;1564437989]4.5 BS and tall tires puts the sidewall into the frame on lock to lock.
No one makes tires to fit that rim with the taller sidewalls anyway...so I guess I will go with the 17 18 combo with c-5 size tires. Thanks for the input
Old 03-07-2008, 03:54 PM
gkull
gkull's Avatar
I was going to ask you about where did you find 55 series 17's
To 16X9.5 or 17X9.5 wheels all around
Quick Reply: 16X9.5 or 17X9.5 wheels all around
