Royal Purple Synchromax Manual Transmission Fluid
I assume the answer may be no, but can you run Royal Purple Synchromax Manual Transmission Fluid in a 1969 M21 manual transmission?
Received 4,558 Likes
2016 C2 of Year
2015 C3 of Year Finalist
It's designed to run on 80/90 gear lube. That's what I have always used. The synthetics are too slippery to protect the gears.
I think Synchromesh is a little light for this type of transmission. I have ran synchromesh in the TKO that is in my car. Someone else please confirm this for us. I did however run Mobil synthetic gear lube in my M20 when I had this transmission. It seemed to help the M20.
Nope, you cannot run Synchromax in your Muncie. This lube is basically automatic transmission fluid and is designed for the T-5, T-56, and some of the newer manual transmissions. Stick with the recommended 90W.
I'm using RedLine's manual transmission oil in my Richmond 5 speed. The transmission shifts MUCH smoother now than when I had a synthetic gear lube in it. Little pricey, but well worth it .
http://www.redlineoil.com/products_g...7&categoryID=7
1 Post
Cruise-In IV Veteran
Cruise-In V Veteran
I think that if you look at the Royal purple website the appropriate gear oil would be the Max-gear 75w90 or 80w90.
You could also call royal purple.
