Question on handling
Old Jul 5, 2008 | 06:16 PM
bruiserman's Avatar
bruiserman
Navigator
Default Question on handling
I have my 1980 Vette on the road now and love driving it. The only thing I don't like is that it tends to get squirrely on the road. If I really get on it it weaves a bit and then straightens out, if I hit the brakes hard it weaves a bit and then straightens out. Is something worn out or loose? Most of the front end is new. The rear isn't. Not sure where to start with this one. Brakes were bled recently, power steering lines have been replaced recently. The steering wheel is very sensitive to imput as well. Is that normal?
Brian
Old Jul 5, 2008 | 09:56 PM
Vette80regon's Avatar
Vette80regon
Hmmm.... Well,
I too have a 1980. When I first bought it, the tires had flat spots from sitting so long and definitely needed balancing. New tires with a proper balance made huge improvements which were immediate & needed. Are your tires old (came with purchase)? If so, get them replaced. If not, get them balanced & check pressure.
Eventually, I went down this improvement path...
1. Steering box rebuild (rebuild your existing box)
2. Bilstein shocks. (Sport) in my case
3. Replace power steering pump, control valve & Cylinder.
4. Replace bushings
5. New (oem) Rag Joint
6. You indicated new brakes. Are these "new" that prior owner said were new? (which means 4 years old ) or, are they indeed new pads,controller, fluid & lines?
Once those are tackled, put on a VB&P 360lb rear shock (imo) and 550 front coils.
The 1980 handles 100% better.
good luck, but like posters said, before spending $ first check the easy stuff like a tire check. (balance, pressure, flat spots etc)...
Old Jul 5, 2008 | 10:42 PM
SIXFOOTER's Avatar
SIXFOOTER
check for the worn stuff before shotgunning parts so you learn what is going on. What you described sounds like worn TA bushings or missing TA shims so start there..
Old Jul 5, 2008 | 11:03 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If movement is coming from the rear, I'd look at the TA bushings.
Old Jul 5, 2008 | 11:06 PM
Peterbuilt's Avatar
Peterbuilt
PG.
Old Jul 6, 2008 | 12:19 AM
bruiserman's Avatar
bruiserman
Navigator
thanks guys, I will start looking at these things. By the way, what does TA stand for. I'd like to get the car to handle nicely. I can tell at times that it can be a nice handling car but then it likes to act up some times as well.
Old Jul 6, 2008 | 12:49 AM
Vampyre's Avatar
Vampyre
TA - Trailing Arm
Old Jul 6, 2008 | 12:59 AM
onaqwst's Avatar
onaqwst
check to see if the rear strut/camber rods are tight..... they might have some play with the egg shaped washer and giving you .5" or so each side......maybe????
what about the diff. bushing?
b
Old Jul 6, 2008 | 12:02 PM
Jim_Harrison's Avatar
Jim_Harrison
Also check for play, in the half shafts, in your differential. If you can move them out more than .015 inch then they can be worn, not serious but if they move a lot the retaining ring inside could be broken, and needs to be fixed.
To Question on handling
