Shock Absorbers for my c3
Old 08-04-2009, 01:27 PM
behardt91
behardt91's Avatar
Default Shock Absorbers for my c3
In your opinion or from experience, who makes the best shock absorbers for a c3? I know I'm not going to get a much smoother ride because that's how the vette was built but I'm just looking for the best all around shocks for around 200 dollars.
Old 08-04-2009, 03:34 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I completly rebuilt the entire suspension on my 71 Coupe and used Koni shocks. Very happy with them.
BC
Old 08-04-2009, 03:59 PM
RadicalPursuit
RadicalPursuit's Avatar
Default Shocks
I used GM performance shocks. Price was right.
Old 08-04-2009, 04:28 PM
OregonVette80
OregonVette80's Avatar
in my opinion...
if you're asking this question and wanting better suspension response,
just get:
Bilstein Sport shocks
VB&P mono composit rear spring
550# front springs
drive happy
Old 08-04-2009, 04:35 PM
RobbSalzmann
RobbSalzmann's Avatar
St. Jude Donor '12
Originally Posted by OregonVette80
in my opinion...
just get:
550# front springs
drive happy
OregonVette80, which rear spring matches up with the 550 fronts?
Old 08-04-2009, 04:47 PM
OregonVette80
360lb
Old 08-04-2009, 07:34 PM
jb78L-82
jb78L-82's Avatar
My 78 L-82 4 speed came with the gymkhana/F-41 suspension and is completely rebuilt with 550 front springs (1 inch shorter than stock in height) and a composite 360 rear spring. I have had Delco, KYB gas a just, Koni oils, and Bilstein Heavy Duties and the Sports. I currently run Bilstein HD's in the front with the 550 springs and Bilstein Sports (30% stiffer than the HD's in the back) with the 360 spring. By far, the Bislteins are the best compromise between ride and handling. The Bilstein HD's will actually make the ride MUCH better than OEM type shocks. I also have a 1994 Mustang GT convertible that used to ride real choppy with the OEM shocks and I changed to Bilstein Heavy Duties with no other changes and the ride is really quite nice now (no choppiness at all) and handles better! Go Bilstein!!
Old 08-04-2009, 08:28 PM
PeteZO6
PeteZO6's Avatar
Since you said the best shock absorber, then you want Koni. Yep, they are pricey, but that is because they are manufactured precisely to very close tolerances. You should expect at least 100,000 from a set, and probably more. They are adjustable too. My 2¢.
Pete
Old 08-04-2009, 08:31 PM
fugawi
fugawi's Avatar
just bought four bistiens fromwww.eshocks.com for $303 delivered.
Old 08-04-2009, 08:39 PM
larryg3
larryg3's Avatar
i have the VBP street slalom with 550 coils in front 360 mono sprin g in the rear and bilstein all around wow it is great!!!
but as you stated in your post your budget is 200.00 so i guess for that amount go with the AC delco.
To Shock Absorbers for my c3
Quick Reply: Shock Absorbers for my c3
