383ci Shopping list for 1980 4-speed
Old 10-31-2009, 01:56 PM
C3Paul
C3Paul's Avatar
Default 383ci Shopping list for 1980 4-speed
Hi
I am building a 383ci for my 1980 with 4-speed Manual gearbox and standard rear end with 3.07 rear gear and a wide ratio trans with a 2.88 to 1 first gear. This is a final drive ratio of right at 9 to 1.
The goal is to get Street driven fan car with 9.9:1CR, running on 91 US octane fuel with up to 6000RPM and app. 400HP.
The engine is post 1986 block with Roller Camshaft
This is the shopping list so far:
Can you please help me to fill what else I will need, please.
SHORT BLOCK:
Block: http://www.summitracing.com/parts/NAL-10105123/ got at home
Crank: http://www.summitracing.com/parts/SCA-935060L/ got at home
Balancer: Pro Street 6.75” Internal got at home
Fly Wheel: http://www.summitracing.com/parts/NAL-14088648/
Rods: http://www.summitracing.com/parts/SCA-26000716/ got at home
Piston: http://www.cnc-motorsports.com/produ...99&CtgID=16047
Cam: http://www.summitracing.com/parts/LUN-501A4LUN/ will ask for STEP Nose
Timing Chain: http://www.summitracing.com/parts/CCA-3136/
Timing cover: http://www.summitracing.com/parts/MRG-4590/ got at home
Oil Pan: http://www.crateenginedepot.com/stor...557558-954.htm
Pan Gasket: http://www.summitracing.com/parts/FPP-1886/
Oil Pump: http://www.summitracing.com/parts/MEL-M55/ got at home
Oil Pump Shaft: http://www.summitracing.com/parts/MOR-22070/ got at home
Oil Pump Spring: http://www.summitracing.com/parts/MRG-26/ got ...
Lifters: http://www.summitracing.com/parts/CCA-850-16/
Instalation kit: http://www.summitracing.com/parts/CCA-08-1000/
Main bearings: http://www.summitracing.com/parts/CLE-MS909P/
Rod Bearing: 8x http://www.summitracing.com/parts/CLE-CB663P/
Flywheel bolts: I would like Hex-style bolts
Balancer bolt:
Clutch:
TOP END:
Heads: http://www.summitracing.com/parts/CCA-12318/ got...
Head Gasket ??????? will make a decision when the block is back from machining
Rocker arm studs: http://www.summitracing.com/parts/ARP-134-7104/
Rockers: http://www.summitracing.com/parts/LUN-85300LUN/
Pushrod Guide plates: http://www.summitracing.com/parts/CCA-4808-8/
Ex. Valve: http://www.summitracing.com/parts/MAN-10549-8/
In. Valve: http://www.summitracing.com/parts/MAN-10550-8/
Valve keeper locks: http://www.summitracing.com/parts/CCA-611-16/
Valve seals: S-5325 www.competitionproducts.com
Spring retainer: http://www.summitracing.com/parts/CCA-740-16/
Springs: http://www.summitracing.com/parts/CCA-987-16/
Intake: Edelbrock RPM with Rochester Q-jet and 1980 twin intake Air lid
MSD Ignition: http://www.summitracing.com/parts/MSD-8362/ got...
Timing Gear for Roller Cam: Will ask Lunati
Distributor Dyna Module: http://www.ecklers.com/product.asp?p...1&dept_id=1785 got...
Fuel pump: http://www.summitracing.com/parts/ACF-41240/ got...
Fuel pump push rod: http://www.summitracing.com/parts/CCA-4607/
Gasket set: http://www.summitracing.com/parts/FEL-KS2666/
Old 10-31-2009, 02:44 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
need one of these with bolts.
http://www.summitracing.com/parts/NAL-14101116/
Old 10-31-2009, 03:16 PM
Little Mouse
Little Mouse's Avatar
Originally Posted by 63mako
he has an instalation kit listed CCA-08-1000 but its not that cheap in cost.
Can you look up the other parts that hold the lifters, the cam plate ?
he will need a pilot bushing, wonder if the same pilot bushings fit in the one piece seal cranks that the early cranks used ?
Maybe something like a spec clutch will come with all of it down to the throwout bearing and pilot bushing.
C3Paul are you going to measure the pushrod length.
Old 10-31-2009, 03:49 PM
C3Paul
C3Paul's Avatar
[/QUOTE]
Yes I will!!
Old 10-31-2009, 04:18 PM
SteveG75
SteveG75's Avatar
Those 180 cc RHS heads are going to hold that cam back. Look at something around 195 cc or so. Cheaper isn't always better.
Old 10-31-2009, 06:02 PM
C3Paul
C3Paul's Avatar
I have to work with what I have.
At the end of the day, if I go with bigger heads I will gain more power and rev higher.
With my current combo I am looking 400HP/400Tq and this is all I want!!
Old 11-01-2009, 07:46 AM
gkull
gkull's Avatar
Received 1,331 Likes on 1,059 Posts
I would not build an externally balanced motor!
Your existing Damper will not work with your choice of crank and flywheel
Old 11-01-2009, 09:20 AM
LFZ
LFZ's Avatar
No clutch picked yet? Go CenterForce DF. Used the same clutch twice on two different motors, and I love it. Especially for anything sub 550hp.
ARP Balancer bolt recommended as well.
Old 11-01-2009, 12:13 PM
Little Mouse
Thats what it calls for on the one peice seal scat crank a nuetral
balancer and an external balanced flywheel both on there web site
I called talked to scat on the phone.
Nuetral 350 balancers won't fit later crankshafts ?
Old 11-03-2009, 05:07 PM
C3Paul
C3Paul's Avatar
tt
Any help most welcome
Thank you
To 383ci Shopping list for 1980 4-speed
Quick Reply: 383ci Shopping list for 1980 4-speed
