Rear suspension setup help.
Old Oct 12, 2009 | 08:26 PM
Grumpy 427's Avatar
Grumpy 427
Default Rear suspension setup help.
I installed the new composite spring, and it has one hell of an arc to it. Can i jack it up into place so that the 8" bolts will go through the hole? Or what is the correct way to connect this up?
Old Oct 12, 2009 | 08:31 PM
KevinK's Avatar
KevinK
Put a c clamp on it, so the jack doesn't slide, then you jack up the ends, and install the bolts, then let the jack off. It can be a pain getting the bolts both in, they have to be at JUST the right angle, but with enough jiggling, they eventually set in.
Old Oct 12, 2009 | 09:09 PM
Grumpy 427's Avatar
Grumpy 427
Awesome thank you for the reply.
Old Oct 12, 2009 | 10:28 PM
72LS1Vette's Avatar
72LS1Vette
Don't forget the bushings that go on the bolts.
Rick B.
Old Oct 12, 2009 | 10:35 PM
Grumpy 427's Avatar
Grumpy 427
Yes i know about the bushings lol i was just trying to give you an example .
Old Oct 12, 2009 | 11:02 PM
wcsinx's Avatar
wcsinx
That is one clean a$$.
Just to expound on what others have said, I personally like to sandwich 2 thin wood planks with 2 c-clamps. That way I don't run the risk of marring up the glass spring.
Old Oct 13, 2009 | 08:28 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
One additional tip is to jack up the trailing arm to achieve the proper bolt angle. That might make it easier to get the bolt in.
Old Oct 13, 2009 | 08:42 AM
mysixtynine's Avatar
mysixtynine
I found on my 69 that a 2x4 long enough to butt up against the spring mounting plate and extend out to the end of the spring just before the bushing plate is a great way to jack it up into place. Use 1 or 2 small ratchet straps to bind the 2x4 in place (like a splint to locate it) and jack up on the end by the bushing plate by catching the end of the 2x4 in the cup of the jack. Leave enough room so you can install the bushing washer and bolt.
This way you don't have to clamp down on the spring itself.
Really didn't take much pressure to put in in place. I used the same process to remove the old steel spring. Felt very safe. With the ratchet straps and butt'd against the mount plate it could not slip.
Old Oct 13, 2009 | 11:08 AM
Grumpy 427's Avatar
Grumpy 427
Great tips guys, thank you very much for the help.
Old Oct 17, 2009 | 03:59 PM
Grumpy 427's Avatar
Grumpy 427
Ok i got them in this afternoon, does this look correct? The sway bar does not connect to the trailing arms, I am not sure if its the spring or the shock thats holding it from compressing enough? I guess once i get some weight on the rear of the car and it sits all winter the spring may relax enough. If i try to jack under the trailing arm, it only goes so far then lifts the entire car off the jack stands. I ended up using the 8" bolts.
Old Oct 17, 2009 | 04:57 PM
Paul L's Avatar
Paul L
I'm guessing you are using poly cushions.
Old Oct 17, 2009 | 05:03 PM
Grumpy 427's Avatar
Grumpy 427
Yes i am, i had to cut the top ones in order to get them to fit in the trailing arms, and also to get the swaybar mounting plates in. Do the stock rubber ones make a difference?
Old Oct 17, 2009 | 05:05 PM
SteveG75's Avatar
SteveG75
Spring will not relax. My composite spring has not relaxed in over 12 years. The TRW springs have way too much arch and need longer bolts. Mine are almost 10" long.
Old Oct 17, 2009 | 07:53 PM
Clams Canino's Avatar
Clams Canino
Did you drill your T/A's for an aftermarket rear swaybilizer bar?
Did they give you a template? I'm facing this part this week. I don't want to drill them wrong.
-W
Old Oct 17, 2009 | 08:00 PM
Grumpy 427's Avatar
Grumpy 427
Ok well i can take it apart again and get 10 " bolts if i need too.
Old Oct 17, 2009 | 08:01 PM
Grumpy 427's Avatar
Grumpy 427
-W
No my stock trailing arms were drilled for a sway bar, but the car never came with one. The kit comes with a plate with 2 nuts welded to it already, and it all lined up.
Old Oct 17, 2009 | 08:29 PM
Clams Canino
Does the inside nut plate just fit flush with the edge of the T/A?
Can you get a pic up of the top of the T/A please?
Or is it sufficiant to say "centered on the T/A and centered on the bolt hole"?
Also... was your frame already drilled with the nuts in there?
-W
To Rear suspension setup help.
Old Oct 17, 2009 | 08:45 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Damn Grumpy, it's just way too clean under there.
Old Oct 17, 2009 | 11:41 PM
Grumpy 427's Avatar
Grumpy 427
LOL yes i am very fussy, maybe a bit **** about it? Thanks, it took 5 days and nights to clean scrape and undercoat the body, hope to never have to do that again?
Old Oct 17, 2009 | 11:43 PM
Grumpy 427's Avatar
Grumpy 427
-W
The nut plate fits flush, and i think the holes were drilled off center? I came down with a nasty sinus cold right now, and have to work tonight too, i will try to get a couple pictures Tomorrow after i wake up.
