Clock does not work 78
Old 03-29-2010, 08:07 PM
78 C3 Light Corvette Blue
Acct suspended by request 19 April 2011
78 C3 Light Corvette Blue's Avatar
Default Clock does not work 78
There is no wire to it. I don't understand how they work. Do we just replace them. I see kits available don't want to try that.
Old 03-29-2010, 08:30 PM
dar322
dar322's Avatar
St. Jude Donor '12-'13
dont go the quartz path unless you have to. i bought a quartz last summer and it would stop working on its own. on a hunch, my buddy decided to clean the orig clock. it went back in my car and has been working since. i was charged a 15% re-stocking fee.
Old 03-29-2010, 08:34 PM
Bowerss2
Bowerss2's Avatar
rebuild it yourself, its easy, mine worked no problem. Basically you just blow the crud out of it and put some light oil on it, clean the contacts and your good to go!, search on the forum there is a VERY handy guide.
Old 03-29-2010, 08:42 PM
thanks
Old 03-29-2010, 09:51 PM
...Roger...
...Roger...'s Avatar
Printed circuit supply's the power
Old 03-29-2010, 10:12 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Well...it's supposed to, anyway...
Old 03-30-2010, 02:20 AM
speedreed8
speedreed8's Avatar
http://pcfred.com/Vettetip/FixC3Clock.htm
Old 03-30-2010, 06:27 AM
Old 03-30-2010, 09:29 AM
...Roger...
Good Point !
Old 03-30-2010, 09:25 PM
C3 4ME
C3 4ME's Avatar
I disagree with the post of not going with the quartz conversion if you rebuild yours. I put a quartz conversion on mine a little over a year ago, and mine hasn't missed a beat since then, and has kept perfect time ever since.
Old 03-31-2010, 02:45 AM
Corvettetodd
Corvettetodd's Avatar
My quartz conversion has kept perfect time in the few months I have had it...
Old 03-31-2010, 04:46 PM
Priya
Priya's Avatar
I've owned aprox 40 cars in my time, I've never seen a non-quartz clock that kept time and never seen a quartz one that didn't.
Old 03-31-2010, 04:52 PM
Paul L
Paul L's Avatar
I agree. But when you use a battery disconnect as I do a clock does not make sense.
Old 03-31-2010, 07:44 PM
Old 03-31-2010, 08:30 PM
drwet
drwet's Avatar
I installed the quartz conversion in mine shortly after I got my '79 in 1993. Its been keeping perfect time ever since. Watch - now that I've said that it wont be working next time I use the car
Old 03-31-2010, 08:40 PM
chvet73
chvet73's Avatar
My quartz has worked perfectly for 12 years.
Old 03-31-2010, 09:02 PM
dar322
dar322's Avatar
maybe it was my car that wasn't happy with the quartz not being NCRS. after I returned it, the vendor bench tested it and it was perfect. But the week it was on my car...it was a piece of junk. Surprised me, considering how much it cost.
Old 04-20-2013, 10:19 PM
78VettePlus
78VettePlus's Avatar
I would agree with those on the quartz conversion side. I have had a 68 Camaro with Mechanical clock, - fried the electrics and not worth rebuilding at the time. Put an Autometer clock in the same place and it works fine, good timekeeping, low power drain, no hassle.
I bought a 70 Mustang. The mechanical clock I was able to get working with a clean and oil, and the electrics worked, but it kept bad time.
All mechanical clocks need some care and calibration to keep them timing right, and in old cars they get very dirty and prone to failure. You can fix anything, of course.
I just changed the movement out in my 78 Corvette last week, from mechanical to quartz. it is working fine now. Looks original. No maintenance. Easy problem fixed. If you follow the instructions that come in the box it is a snap.
You could spend dollars on a rebuild for your mechanical and it may not keep time, and the electrics can fry or stop.
There has to be a reason that nearly EVERY C3 clock is not working, right? Maybe it was bad quality contacts or weak motor, or bad movements, but they all seem to be bad. I would not bother with fixing something that is most likely to fail again.
Old 04-20-2013, 11:03 PM
bruisedknuckles
bruisedknuckles's Avatar
Not sure if its the same clock as the one on my 77, if it is, fix it yourself. There is a great post here on this form - here is the link:
If its anything like the 77, the mechanism is very rudimentary and quite honestly a ****** design, but nothing beats fixing it.
Basically, when the contacts meet, it creates a spark that throw the contact arm out, which in turn winds the spring. The arm slowly moves back until it the circuit closes again and repeats, that's why you hear a click every 30 seconds or so.
I cleaned the contacts with sand paper, sprayed the hell out of the inside with QD Electronic cleaner, oiled the movement with WD40. There is also a coil on the inside, mine was completely shot. Went down to radio shack, brought the same coil wire, rewound the coil and soldered the end back to the body. The clock has been working ever since, does not keep great time however , but hell, its original.
Good luck!
To Clock does not work 78
Quick Reply: Clock does not work 78
