71 Gauge Guidance Requested...
Senior Member
Received 2,031 Likes
St. Jude Donor '10
I will post this here and in the my Brandshatch Green Barn Find posting to see if anyone knows of a tach and speedo refresh service for my 1971 guages. I am interested in either having these repainted or replaced with newly repainted faces if that works better. I'd like them cleaned inside and tested to make sure they sweep without sticking as well. If you know of one please sound off here, PM me or e-mail me please.
Thank you.
David Howard
Speedo has light surface rust on face surface, rust on face screws, surface rust on housing and the sweep arm sticks when in use.
Tach has light surface rust on the face, surface rust on the housing and sweep is good on the tach.
Thank you.
David Howard
I had my 71' Speedo restored by "Corvette Clocks by Roger". Cost was $220 in 2005 and the thing looked like new when returned.
Gary
http://www.corvetteclocks.com/
Gary
If there is rust on the faceplate, then the gauge certainly has seen moisture inside it and will need to be thoroughly refurbished. Google "Speedo Tach Repair" and several sources will come up. I cannot vouch for any of them, but I would suggest that you select one which others [who have had that work done] can recommend.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
David-
I can do these gauges for you and would love the opportunity!
I'll do them myself!
Ernie
Ernie
Senior Member
St. Jude Donor '10
Senior Member
St. Jude Donor '10
Best regards,
David
Senior Member
St. Jude Donor '10
Gary
Gary
Can you tell us why you picked them over the other choices?Price?Thanks
Senior Member
St. Jude Donor '10
