Fan Blower Speed - only High Works
Old 03-27-2017, 05:00 PM
  #41
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Jerry82
thank you very much for the info!!!!
My pleasure! Here is the diagram that went with this post. I changed my hosting site so the link above is probably dead now.
Old 11-01-2017, 04:17 PM
  #42
RobertLang
5th Gear
RobertLang's Avatar
Originally Posted by noonie
You are aware that the high speed uses a different feed circuit and fuse than the lower speeds?
Logged in today because, MY FAN ONLY RUNS AT HIGH SPEED. Just started doing this. Note, it is supposed to run LOW speed whenever the key is on.
So, I take your advice and look for AC/Heater fuse. I see ONLY ONE. I take is out. I inspect it. I use a meter to test it. It looks and tested GOOD.
With this fuse OUT, the high speed does NOT run. . . . . so, I put it back in.
Now, BLOWER WORKS ON ALL SPEEDS. What the frick is going on????
Quick Reply: Fan Blower Speed - only High Works
