idle mixture screw tool
I don't know if you mean the clutch head screws that were used in older carbs. But I bought a cheap screwdriver and socket set, which has all different size phillips, straight head, and torx head ends that slip into the magnetic screwdriver shaft. There are also a couple of rectangular shaped ends, which must fit the application you have.
Grumpy
If you mean those nasty little Q-Jet idle mixture screws, I too need one. The guy at the local vette shop has a nifty driver with a long flexible shaft that fits right over those little buggers. Makes it real easy for getting on and off quickly, with the engine fan blowing hot air right in your face.
FR
FR
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
NAPA stores and most other auto supply stores (including Mac Tools and SnapOn) have the tool for about $4. Just buy the tool.
Lars
Lars
