69 427 dipstick color/pics
Ok, so I got the correct length dipstick tube and dipstick for my 69 427/390, what color should they be? Pics would be great. Thanks in advance...
Received 4,576 Likes
2016 C2 of Year
2015 C3 of Year Finalist
The finish of both the dipstick and the tube should be natural, not painted. Big blocks should have a red colored, plastic plug in the end.
Received 2,878 Likes
Hi ccv,
The info I have indicates the gauge and tube are 'natural'; sort of a dark gray. The guage handle had a white plastic plug in the end originally.
Here's a picture of the gauge on my small block w/black plug, ( I should be so lucky as to have a 427 car), I'd think the bb gauge would be the same material and finish.
Regards,
Alan.
Regards,
Alan.
65-67 use the same tube as the 69, but have a salmon colored plug.
The dipsticks are all a natural, unpainted finish.
Hi ccv and cape,
You beat me to it while I was looking for my picture.
I'm thinking the red button was for 70+ model year BBs maybe?
Regards,
Alan
PS: Well this is really getting out of sequence now!
Regards,
Alan
2016 C2 of Year
This is not correct, late 67 trough 69 BB's used a dipstick with a white plastic plug. The red one was used with 70-74 BB's, which is a different length dipstick and uses a completely different tube.
"Small blocks have a black plug, and 427 engines have a red plug, which may be faded. Finish of the dipstick is natural."
I just went out into the garage to confirm: My 68 427/390 is all original under the hood and it has the red plug and natural finish. The red plug is at the end of the circular portion of the dipstick where your finger goes as you pull the dipstick out.
At the risk of sounding argumentative You are incorrect. I will read from the 68/69 Judging Manual for 68/69:
2016 C2 of Year
There was quite a discussion on the NCRS board last fall regarding this very subject. Apparently the late 68 to early 69 BBs had a white plug. My 69 non-A/C BB was buit in April and has a white plug. Late 69s or those with A/C were being debated...red plug, various lengths...no firm resolution.
Hi m7,
It appears that your red plug would be typical for a 71 bb car.
So, you can sleep soundly tonight, or find something else to toss and turn over.
Regards,
Alan
Regards,
Alan
Thanks all, that means I can just install my Willcox dipstick and tube as is, without any "I may as well...paint/prep/rebuild/repair/make look orig extra steps", one step closer to summer cruising, I appreciate the feedback...Michael
The 69 assembly manual lists the dipstick as part number 3959158, and the tube as 3870324. This is the white button dipstick.
The red button dipstick is part number 3981089 and the tube is 3981088. This is the dipstick that was used in all 454's. This dipstick and tube, are longer than the 396 & 427 dipsticks.
Chevrolet discontinued the the white button dipstick in 70 or 71. The only dipstick listed in the 1972 Parts Book for any 396, 427, or 454, is the red button dipstick, 3981089. The parts book notes that if you are using this dipstick, it must be use with tube 3981088.
Because Chevrolet discontiuned the white button dipstick so soon after introducing the red one, the red one was the only one available for years, and ended up on a lot of BB Corvettes. I think that it's been less than 10 years, that the info about the white button dipsticks, has been known. I don't know how long it's been since the 68-69 Judging Manual has been updated, but I'm guessing that the next edition will list the white button dipstick for BB's.
If you want that dipstick to remain 'natural' colored (instead of "rust" colored), I suggest you give it a shot of clear engine enamel.
WD-40 will dry-up pretty quickly. If you want to keep it totally 'natural', a thin wipe of 3-in-1 oil would do better for you. Either way, use lacquer thinner to clean it off really well before putting clear on it.
Jeez..... Of course I had to walk out to the garage (detached) in the rain to see whats on mine. I knew it was the natural finish but never noticed the plug. Mine is red - 69 427/390 - and original as far as I can tell.
Hey guys this got me lookin at my dipstick can somebody give the dipstick tube length and corresponding dipstick overall length and length from stop to tip.
I don't have original engine and have three different dipsticks and tubes I can use all different in some way.
Pretty sure I have the correct oil pan.
Thanks for any help.
