Want to remove my front rotors
78 Have the calipers off. Drilled out the rivet heads. Rotor doesn't budge. Is there a secret to getting the rotors off? Do I need to remove the hub and rotor or can I get the rotor off with muscle and wd40? Thanks
You might want to pry off the dust cap, remove the cotter pin and castle nut, then pull the rotor (along with outer bearing race and washer).
Went through the EXACT scenario today. As mentioned above, I removed the dust cap, pulled the cotter pin, removed the castle nut and pulled the whole assembly. (good time to replace and re-pack the wheel bearings)
Drilled out the rivets, took a small piece of 2 x 4 to the hub and gave it a couple of whacks. This is also a good time to replace the wheel studs, it's a cheap and easy preventative maintenance measure.
Keep the shiny side up!
Scott
Make sure you pack the bearings correctly or else you will run a spindle, maybe loose a wheel, or something worse. You need to know how to set the wheel nut also.
Received 1,469 Likes
Cruise-In II Veteran
The secret is not to remove them. Do you need to remove them? Rotors seldom need to be replaced and you can rebuild the brakes without replacing them.
If you do remove them, index them first. For run out purposes, they have to be installed in exactly the same position if you intend to reuse them.
Rotors on C2/C3 Corvettes are not low cost mileage limited routine throw-aways like on modern cars. Time has proven that the original rotors last well over 100,000 miles with replacement or 'turning' needed. They were NEVER designed to be separated from the hubs in the field and casually replaced with new ones. GM only sold completer hub/spindle and rotor assemblies.
Changing them 'just cause' as many owners do brings all sorts of drawbacks as Easy Mike mentions.
And in addition, if you have the rotors turned by someone that is not aware of the fixed caliper design, they can inadvertently cause you problems. If the rotors have to be turned, you need to remove the same amount on BOTH sides of the rotor. Otherwise, the rotor is not centered in the pads.
Fronts aren't that hard to replace though. Bolt the rotor to the hub, chuck it up in a brake lathe and cut it until it's true.
The rears which have to be shimmed or machined on the car are the pain to replace.
I never drove like a little old lady. I usually got 2-3 pads before the rotor were worn too thin. Carbon metalic and hawk pads eat rotors. I have stacks of stock type rotors that just need a resurface. Run out is always needed. I have done lots of vettes brakes over the years and i just use an air cutter wheel to grind the heads rivets off. Then a big punch
