454 For Sale that I would appreciate some feedback on
What do you guys think. You guys gave me some great feedback on a 383 a couple weeks ago. I found this on CL and it seems like a good buy to me. Trying to find a donor motor for my Chevelle, it's 307 doesn't read to high on the fun meter.
Questions
Is this a good value?
Any watchouts on the description?
Any questions I should ask for more clarity?
I appreciate the help and feedback from the smart folks! Years ago my friend bought a 402 of someone and it crapped out after about 500 miles. Trying to avoid that........
Enough of my blathering, heres the ad
I am selling a Rebuilt 454 Chevrolet Big Block Engine from intake to oil pan. It has never been run since it was professionally assembled. I rebuilt it to LS5 specs with a little more cam, and was going to use it in my 70 Chevelle until I recently purchased a 1970 Dated LS6 engine. I am selling this one and using the correct dated LS6 for my car instead.
Here is a list of everything in it and done to it.
2 bolt Block Casting number 14015445 date code D 22 80
LS5 Oval Port Closed Chamber heads Casting number 3964290 date code J 23 9
Block has been Bored .060 over .060 over = 468 Cu. In
Decked square
Align honed
Heads have 3 angle valve job, resurfaced, cut for seals, and dual springs and retainers installed
Standard crank Mic'ed & Polished
3/8'" bolt resized connecting rods
Sealed Power H-426CP-60 LS5 dome style Pistons 9.75 to 1 compression
Speed Pro Moly rings
Clevite Standard Main & Rod Bearings
Double roller timing chain and gears
Crane Hydraulic flat tappet cam 300 in. 310 ex. advertised duration, 224 int. 234 ex. @ .050 , on a 114 CL, Valve Lift .525 int. .553 ex.
Crane Gold roller rockers
3/8" guide plates and 3/8" Speed Pro Pushrods
Mellings Hi volume oil pump
Fel-Pro gaskets
Moroso Gold anodized covers ( covers have scratches and dings)
Edelbrock Streetmaster intake manifold (accepts Holley or Q Jet carb)
Asking $3200 OBO Serious inquiries only
https://cf.searchtempest.com/go-1.1....060211546.html
Questions
Decked square
Align honed
Fel-Pro gaskets
I have a spare stock 454 that I wouldn't part with unless serious money was offered for it. What you found sounds like a heck of a deal. Thers's no way you can buy an engine and parts and get the machine shop work done for that kind of money. I can't tell you how many 307 me and my buddies junked when we were younger. Just not enough HP in them.
Seems like a pretty decent deal... Id say that is probably about a 400-425 hp motor, pretty nice combo of parts.. As long as its built right, its worth $3k...
BTW 445 casting blocks are 4 bolt mains.
The only thing that would slightly worry me is that it's already 060 over. It might have another bore in it, but it may not. I'd feel better about it if it was 030 or 040 as that means at least one more bore.
But I still think it's worth the asking price unless the machine shop messed it up completely.
Thanks guys, it seemed like a good deal. I'm a novice and want to make sure I'm buying something I can use. I want to make sure I'm not getting into something that is race only, or built with a combination that doesn't make sense.
Thanks again :o)
Thanks again :o)
My engines had 4 bolt mains with 7/16 rods, aluminum heads, 12.5 to 1 compression pistons, etc.
Received 3,043 Likes
St. Jude Donor '05
For the money, as others said if it was done right grab it!!
BBCs arent cheap to do.
Received 2,878 Likes
Hi Rich,
I believe the casting number and date indicate it's a later block that was intended for use in a light duty truck.
14015445….454….2 or 4 bolt….1978- 1990 (years used)….Truck LD.
April 22, 78 or 88. If the pad is stamped the broadcast code might help indicate which of those years it was cast.
Regards,
Alan
Regards,
Alan
RichS23 (12-13-2015)
what changes will you have to make for BB on Chevelle? Mounts, crossmember, brakes, springs, tranny?
Nevermind
