'80 C3 Fuse box??
'80 C3 Fuse box??
Okay, so this is my very first post on this GREAT forum!
I'm glad I can finally be amongst fellow 'vette lovers!
So since I've gotten myself an 1980 'vette that's a little
bit of a project due to previous misuse, or say "prior ownership abuse".
I thought I'd swing by the coolest forum EVER...for a question, or a zillion!
My first question is about my fuse box.The fuse box just doesn't seem
right. I looked at diagrams on the web and they don't match
my box in my '80. I have a couple of pictures that may help. I'm just wondering
if everything looks like it's supposed to be. So far I've had dash lights half out, no radio, gauges don't work (except gas), and cigarette lighter doesn't work to name a few. Any suggestions are appreciated!!! P.S. I have no idea how to post pictures.
Received 1,469 Likes
Cruise-In II Veteran
If memory serves, your owner's manual has a pic of the fuse box. Have you purchased the 80 assembly instruction manual (AIM)? The AIM shows the fuse box installation, along with a thousand other things you are going to want to know.
Congrats on the 80.
Congrats on the 80.
this is supposedly the image of the box, I used google "image corvette 1980 fuse box"
http://www.justanswer.com/uploads/mc...hers-Fuses.gif
Yes I have a couple of those, I was having a difficult time
working on my fuse box using the diagram as a reference.
One thing that was throwing me off was the area where there's
supposed to be a circular hazard flasher there isn't one??
this thread has the same box http://forums.corvetteforum.com/c3-t...-question.html
Cannt tell from your picture, are there electrical contacts in the upper left of the box where the flasher would sit? Do they work? This kit shows two flashers also.
http://www.ecklerscorvette.com/corve...-kit-1980.html
[QUOTE = C3fanboy; 1583721219] Non sono sicuro, dovrò scoprirlo! Quindi tutte le altre
parti della scatola dei fusibili sembrano copacetiche? O sono tutti i vuoti
slot supposti per essere riempito con fusibili? [/ QUOTE] buongiorno ho comprato una corvetta 82, e ho trovato questa situazione qui in foto nella mia scatola dei fusibili, mi chiedo perché qualcuno ha collegato i fili in questo mondo e qual è il flo giallo
Cruising
