Share Your C3 Upgraded Wheel/Tire Combo's
Old 12-01-2016, 09:32 PM
  #661
BLACK SHARK
BLACK SHARK's Avatar
Location: In the shop most of the time,,, And it BEER TIME somewhere
The following 2 users liked this post by BLACK SHARK:
ddawson (12-02-2016), Metalhead140 (12-01-2016)
Old 12-02-2016, 11:33 PM
  #662
FNHOSTL1
FNHOSTL1's Avatar
Originally Posted by Metalhead140
Very nice! ...are you a Pantera fan (username)?
An original Cowboy From Hell!
Metalhead140 (12-06-2016)
Old 01-01-2017, 05:43 AM
  #663
stingraymaniac
stingraymaniac's Avatar
Revolution thrust 8x17 and 9.5x17 with 225/55 and 255/50
Ed'69 (03-30-2022)
Old 01-01-2017, 07:22 AM
  #664
worship79
Support Corvetteforum!
worship79's Avatar
That is one sweet combo!!
Had to make modifications for the 9.5" rears?
Old 01-01-2017, 04:25 PM
  #665
stingraymaniac
I have longer 1/2 bolts all around and spacers to clear the trailingarms, don't remember the thickness though
The following 3 users liked this post by stingraymaniac:
Ed'69 (03-30-2022), mitch.1972vette (07-18-2020), worship79 (01-02-2017)
Old 01-02-2017, 05:51 AM
  #666
bap
bap's Avatar
C3 1980 ls9 from Denmark ....
The following 2 users liked this post by bap:
80vette21 (04-04-2020), mitch.1972vette (07-18-2020)
Old 01-08-2017, 08:54 PM
  #667
rajin cajin
rajin cajin's Avatar
Originally Posted by sfsvettes
18x11's up front & 18x12's in the rear <br/>315 BFGs front & 335 in the rear
Very nice.
Ed'69 (03-30-2022)
Old 02-10-2017, 09:37 PM
  #668
bigg_un
bigg_un's Avatar
I have been rebuilding a '74 coupe for about six yrs now...I am nearing the point of buying tires and wheels...is there someone on here that can give me some advice on what will fit this yr model. I would like to go with the torque thrust II wheels...18 x 8's up front and as wide a wheel and tire on the rear as I can without modifications to the suspension...any help would be appreciated...
Old 02-11-2017, 04:57 AM
  #669
gbarmore
gbarmore's Avatar
Fit check, Vintage Wheels, Super Lights, 15" X 8", with 4" backspacing, Hub centric. Going to mount up BFG's 245-60-R15's, front and rear, which is what I'm running now on the stock rally's.
Hey OCB, any pics of the car with the tires on? Love those wheels!
Ed'69 (03-30-2022)
Old 02-11-2017, 06:18 AM
  #670
terrys6t8roadster
terrys6t8roadster's Avatar
If you're willing to relocate the parking brake calbe mount from the side of trailing arm to the top you can run 18x9-4.5 backspace on all 4 corners. You can run any width you want in the rear with a 4" bs. T
Ed'69 (03-30-2022)
Old 02-11-2017, 08:26 AM
  #671
3JsVette
3JsVette's Avatar
Received 2,492 Likes on 1,645 Posts
Are you looking to keep the tires under the wheel openings or you don't care if they stick out past the fender? You can do a search using "18s".
Lately there have been a lot of owners pushing the envelope with getting up to 10" wide wheels all the way around. With 18s the trailing arm is the limiting factor in the rear. There are C3s running 18X9.5 with 275/40s in the rear with 5" backspace with no issues. Don't forget all these cars are old and they can vary from car to car. Always best if you can test fit or if a shop has the wheel fitment tool that mounts the tire and places in the wheel well to determine width and backspace needed for proper fitment.
Ed'69 (03-30-2022)
Old 02-11-2017, 01:35 PM
  #672
FKING1
FKING1's Avatar
On my 70 I have 18x9.5 with 5-1/2 BS on all 4 corners.
1/4 spacers all 4 & relocated both parking brake brackets to top.
Rival S 275/35/18's all 4.
The following 2 users liked this post by FKING1:
Ed'69 (03-30-2022), worship79 (02-14-2017)
Old 02-11-2017, 09:19 PM
  #673
bigg_un
bigg_un's Avatar
I'm thinking what I might need to do is order the front wheels and tires. Then I can use these to look at what I can put on the rear. The car is at the point where all the suspension is back on but the motor and tranny are still out. Do you know what the factory back set would be for stock wheels? I don't mind the rear tires sticking out but if it is going to affect the ride then I would want them up under the fenders.
Ed'69 (03-30-2022)
Old 02-11-2017, 09:36 PM
  #674
rogernison
rogernison's Avatar
Default C3 backspace
The 1969-1982 C3 15 x 8 rally wheels were 4" backspace
bigg_un (02-11-2017)
Old 02-24-2017, 12:55 PM
  #675
OldCarBum
OldCarBum's Avatar
Received 4,698 Likes on 2,938 Posts
Sorry no. Those photos were taken with a set of 15" X 8" during the fit check with the new Wilwood brakes. The wheels fit perfect with the OEM calipers however the tolerances were to tight between the wheels and the Wilwood 6 piston front calipers, so the wheels were exchanged for a set of 17" X 8". The new wheels are on the shelf waiting for the frame off resto/mod of the entire car.
Old 02-24-2017, 10:06 PM
  #676
cagotzmann
cagotzmann's Avatar
These are 18x8 version of similar wheels (Team III LT-III wheels) 245x45Rx18 supersport tires.
Ed'69 (03-30-2022)
Old 03-02-2017, 09:39 PM
  #677
twinpack
twinpack's Avatar
Default lite
Need to see this with mounted tires please
To Share Your C3 Upgraded Wheel/Tire Combo's
Old 03-02-2017, 09:52 PM
  #678
sfsvettes
BubbaHut
sfsvettes's Avatar
Default American VF483
American Racing AF483
18X11 4.5 BS<br/>315/30/18
18X12 4.5 BS<br/>335/30/18
Ed'69 (03-30-2022)
Old 03-03-2017, 02:42 AM
  #679
Alex66
Alex66's Avatar
Looks super!
Old 03-03-2017, 10:02 PM
  #680
3JsVette
3JsVette's Avatar
sfsvettes that's one race ready Corvette. There's lots of wheel and tire under that one and of course a great stance.
Quick Reply: Share Your C3 Upgraded Wheel/Tire Combo's
