too many plugs
too many plugs
i have been installing new lectric limited wiring harnesses in my 72 engine bay, new ign / ac and fwd lamp
the ign goes across the firewall and has the starter and blower motor wires (left / orange wire + earth)
the ac comes out the firewall between the wiper actuator and wiper motor,
and has the compressor, press switches and blower motor (right / purple wire + earth & evac thermo switch(grn/tan)
what am i missing here?
looking at a coloured wiring chart that shows all the connectors, i think i have too many connectors for the same thing...
didnt really look in there b4 i unplugged the old wiring. motor & earth both have spade connectors
there is also a noise capacitor/suppressor with separate terminals bolted to the motor under there as well
which wire do i use, how do wire it up?
Received 2,878 Likes
Hi au,
In the 71 AIM, UPC Sheet C60, Sheet E1, "Air Conditioning -Front Wiring" there is a diagram in the left upper corner with a note that states "cut orange wire from the production blower motor leads with-in .25" of it's break-out from the harness & discarding the connector".
Does that apply to your situation?
Regards,
Alan
Regards,
Alan
there is a "UPC Sheet C60, Sheet E1" in my 72 AIM as well and it says the same.
but...
there is also "UPC Sheet C69, Sheet A4", " radio am/fm capacitors" which shows it using the orange wire...
was leaning towards the purple wire as it comes from the blower switch
thanks again
you must know the AIM inside and out...
but...
thanks again
