1971 Engine stamp with vin sequence
Old 03-07-2014, 05:45 PM
wbriney
wbriney's Avatar
Default 1971 Engine stamp with vin sequence
I am looking at a 1971 corvette convertible and I wanted check to see if car is a matching numbers car. Where do I find the vin number on the engine?
Old 03-07-2014, 06:23 PM
mrvette
mrvette's Avatar
Passenger side, on the block deck that sticks out about 1/2 inch from the front of the cyl head....hidden pretty good by the a/c comp.....shine a light down there maybe have to wipe some grit/oil off to see it clearly, the numbers should all look nice and straight and even depth....
Old 03-07-2014, 06:33 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi wb,
Looking at a 71 convertible!!!! NICE!
The stamp pad contains:
A code that states when the engine was assembled at the plant either in Flint for small block engines, or Tonawanda, for big block engines, and the configuration, (HP, transmission) that it was built-in.
And,
The vin sequence of the car it was installed in at the assembly plant in St.Louis.
Here's a typical 71 sb pad.
Regards,
Alan
Old 03-08-2014, 09:50 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
No disrespect, wbriney, but if you do not know your way around these cars and do not know what you might be looking at when you get there, take someone with you who does.
To 1971 Engine stamp with vin sequence
Quick Reply: 1971 Engine stamp with vin sequence
