77 console wiring questions.
Hi, im in the process of replacing the center console of my car, and the guy who had it last made on hell of a mess under there. Currently, i have a few wires that are clipped. Im fairly certain that one of them is a ground which goes to the clock, but I’m not sure. the wire is black, and thicker than most under there. Also, the radio was hard wired into what i believe is the hot wire (orange) for the cig. lighter, however the cig lighter was disconnected as well…. Iv had a power drain on the battery since i bought it, and now I’m starting to see why…. any help would be greatly appreciated. thank you.
Received 1,246 Likes
Some pictures might help figure out which wires go where.
This might help:
https://docs.google.com/viewer?a=v&p...TUxMDNiMTY3Nzk
This might help:
Hi, my 77 had a battery drain too, I finally traced it to the interior light dimmer relay, which is located under your dash pad just above your tacho
You can check this by disconnecting your interior light door switches which are behind the LH and RH kick panels
cheers Dave NZ
cheers Dave NZ
I do not think that the 77 is a whole lot different than a 71 as far as the lighter and clock go. On my 71 the clock gets its ground from the temperature gauges center black wire it grounds all of the gauge cluster. The lighter wire is orange (single spade) it gets its ground from a black wire that has a "ring" connected to it that fits around the lighter. There is a black ground wire that connects to the heater and A/C control by way of a spade.
I hope this is some help.
1977 gauges and a 1971 are completely different on how they are wired. Not even the same at all.
The big black wire can be the ground for your cigarette lighter...which has a very large eyelet that gets attached when the lighter housing gets installed to the console plate.
Good photos of what you have going on would be great help.
DUB
DUB
DUB
DUB
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The clock and lighter are powered up by the same orange wire circuit.... just in a different manner..
The orange wire powers up the lighter just like all other cars. But the clock power, while on the same orange circuit is in the PCB unlike your car Rocco.
The OP's question about the clock ground.. The clock ground is picked up through the pcb as well.. there isn't a wire out of the pcb connector that is a ground as in other year cars with the grounding terminal.
In most cases.. the ground for the lighter as Dub stated, is on a ring pictured below.
The clock ground is picked up on the 77-82 cars from the pcb as show below.
Where is this cut "black wire" in question located EXACTLY.
Writing that it is coming from the fuse panel is obvious...but where is it cut....i.e. under the radio...under the shifter console...by the fuse panel....under the steering column....by the hood release handle....where????
DUB
DUB
These pics are of the three wires that are unaccounted for. Sorry they are sideways :/
So here is what i think they are for:
The previous owner removed the original radio, and i have a feeling that the yellow, grey, and thick black wire are from the original radio. The current radio is tapped into the cig lighter power. I hope these pics help figure out what these wires are for. thanks.
Former Vendor
You are correct, the original connector used gray, yellow and black. So.. gray we know is a dash lamp (or radio lamp). You can test this by pulling the headlamp switch on and seeing if it picks up power. The yellow would be the power to the radio and is switched when the key is turned on.. so you can test that as well.. I'll bet if two of the three are correct, the third wire probably is the black for the old radio connector. It looks pretty large and I don't have a 77 schematic here to look at to confirm it. Maybe Dub will know for sure.
On another note.. that twist cap wiring would be something I'd yank out in a heartbeat...
Willcox
Willcox
Willcox
Willcox
