Another horn question
I have read the trouble shoot guides and all the postings and diagrams but I'm not understanding how the horn actually works. When I press the horn button is they suppose to push the contacts behind it together to complete the circuit or is that ore of a mechanical spring that pushed the contact switch (button) coming out of the steering column? I see on the trouble shooting guilds that you need to test continuity on the metal plate with the tabs but it's not clear to me what the operation is or what the circuit looks like. Hopefully this request is not as confusing as the horn operation.
Thanks for your help
the contacts on this plate which are separated by plastic come together grounding the circuit causing the horn to sound
http://www.ecklerscorvette.com/corve...1967-1982.html
As MelWff posted. This upper horn contact is just one part of many that is a part of the horn circuit. This part can get dirty and not complete the circuit when pressed.
When it is removed ...which should be done WITH CAUTION and CARE due to the spring loaded plunger under it.
Then...you have another spring loaded plunger made into your turn signal switch...which can be bad due to if the horn was ON for a long time...it heats up the spring and the spring looses its strength....thus that plunger looses contact and thus NO HORN.
There is a difference between a tele-tilt column and a standard column.
DUB
DUB
thanks for the reply's. Just so I understand - the horn button pushes the contact (ring with tabs) behind it together. one side of the contact is always touching the "Brush" (rod on spring). and the other side is ground. this completes the circuit. So if use a volt meter I should get 12 volts at the Brush button and one side of the contact?
WRONG!!!!! The 'other side' is still the same circuit that is going to your horn relay...WAITING FOR A GROUND signal WHEN YOU PRESS THE HORN BUTTON.
SO..I remove the relay from the connector and using an OHMMETER is what I use to verify that the wire from the relay to the plunger under the contact is good. IF NOT...then it can be in the column....but that is when I ALSO verify that I am getting an ohm reading from the relay wire to the turn signal switch connector when it has been disconnected. Then I check the turn signal switch connector at the column and go to the plunger. Then I VERIFY that this wire is NOT grounded.
DUB
Thanks again!
DUB
Just a sidebar to this post. If you are one of the few who do not have a tilt/tele column look for parts in Camaro, Nova, Chevelle. It seems very few were built with the standard column and the Corvette vendors don't address this non option.
All GM locking tilt & telescoping steering columns shared a number of common parts. So the Corvette T&T column shared a lot of common parts with Buick, Oldsmobile, and Cadillac T&T steering columns of that same vintage. Keep in mind that in 1977 the Corvette T&T column went from a completely round head to one that had a large rectangular bulge on the left side of the head (where the turn signal lever attached to the dimmer pivot.) Even the tilt (only) steering columns shared a number of common parts with the T&T column. So round head columns in the 1969 to 1976 era had all the same guts. T&T columns with the dimmer bulge also shared a number of the same internal parts.
All GM standard (non-adjustable) locking, steering columns manufactured in 1969 and later used a lot of the same parts in the steering column head. Same lock cylinders, bearings, turn signal switches, locking plate, etc. Whether the standard column was used in a Buick, Olds, Chevrolet, etc they still used a lot of the same parts. Since the instrument cluster(s) were unique for each car line, the plastic shroud that matched the column to the cluster was different in length, angle, shape etc. but the "guts" of the standard columns were all the same.
Jim
If you are referring to the upper contact....that the horn button clips onto...just be AWARE...that the aftermarket ones...for some odd reason can be hard to get the horn button to clip onto and work. It seems like the spring steel that is made in these contacts is NOT like the factory spring steel. I have encountered this NUMEROUS times. So just be aware. Not writing that you will have a problem...just that one can show up when you go out put the horn button on and then press the horn button and NO HORN...but yet it worked when the horn button was off.
DUB
DUB
This shows the original contact on the left and the new one on the right and the horn button
This shows the horn button attached to the Contact. what am I doing wrong?
It feels like there is no "spring" under the horn button now. Not sure what makes the spring feel of the horn, when the horn button is pushed onto the contact. What pushes the horn button back to the "off" or no contact position?
There are usually shims that are mounted under the 3 screws for the contact to raise it up. It sounds like you need some, then you can push the button down enough for contact and it will spring back up.
http://www.zip-corvette.com/catalog/...-contact-shim/
The movement is a function of the contact assembly, it warps enough to make contact and then straightens back out. The plastic rivets insulate the two pieces as well as hold them together. When you push on one side of the horn button the two parts of the contact will touch internally.
OK - Finally understand the whole horn operation and just 5 mins ago I was able to get it working correctly. Yea!! - but I just broke the screw that holds the sun visor on (don't mess with things that aren't broken). Sucks!
Thank you all for all your assistance!!
