new fuel sending unit not accurate-HELP!
new tank and sending unit now guage reads about half of what it should and ideas as to how to recalibrate sender? It's a 70 BB vert auto, You guys rule, thanks in advance for assistance. Tim.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Pull the ohms wire off the sender and take a ohms reading.... see if that reading matches up with the amount of fuel in the car. 0 - 90 ohms is the scale with 45 ohms being about 1/2 way... I say about because it can and usually will put you over 1/2 tank just as 90 ohms will usually put you a bit over full. Then take a look at the info below.
Willcox
1968-1976 Corvette Fuel Gauge and Sending Unit Testing
click on supporting document.
Or
http://repairs.willcoxcorvette.com/w...it-testing.pdf
Combine this with the help and repair page on our site and you should be able to solve any fuel gauge mystery.
Willcox
Or
Seeing if someone has had this problem
Willcox
Or
Willcox
Or
Not quite the same problem. When I'm 1/2 full the guage reads empty. I'm not sure if it's a problem with the sending unit or guage. Can someone help??
