Radiator air dam on my 72
Installed a new radiator air dam today on my 72. Now the center of the hood at the front is about 1/8 inch higher than the nose. This needs to be a snug fit against the hood for optimal AC performance but I'm concerned the hood may warp over time if left as is. Has anybody else experienced this same problem?
Received 2,878 Likes
Hi D,
I'm surprised the foam air dam is firm enough to lift the hood. If you press down on the hood can you get rid of the 1/8"
Is it possible that the pressure of the hood on the core support air dam will compress the foam rubber a bit in a couple of weeks?
This is often the situation on new door and roof panel weatherstripping… it compresses a bit over time.
I'd watch it for a while and then re-assess the fit.
Regards,
Alan
Regards,
Alan
Hi D,
Regards,
Alan
Regards,
Alan
Dr
Hi dr,
Concerned?
It's certainly something that would pass through my mind too.
I think I'd try to reach up pas the core support from below and try to assess just how much pressure the dam is exerting on the hood.
The only sure thing to do is to trim the dam to put your mind at ease??
Regards,
Alan
Concerned?
Regards,
Alan
