R12 to R134a adapter question
Same thing here, but to charge a 134 car/wife's car, I had to cut a couple hoses and then splice/clamp them together as a miss match to get the correct end.....my gauges are probably 30 years old.....pressure is pressure, but I HATE 134, wish 12 would come back...leaks less....stupid EPA.....
It's been a long time since I did mine, but I remember the large adapter didn't have a valve (old one was re-used). The smaller one had a valve and the old one had to be removed.
A correct conversion includes new o-rings, adjust the POA valve (or replace orifice tube on later C3s), and a parallel flow condenser. And the adapter fittings, of course.
If all the above is done the R134a system will blow as cold as R12.
