Cam recommendations for Vortec 350
Old 10-15-2015, 12:23 PM
Heus
Heus's Avatar
Default Cam recommendations for Vortec 350
I have purchased a short block 357 from ATK Performance. It is a roller cam block 96-01 Vortec with flat top hyper. pistons. I will be going with 64cc 2.20/1.60 heads from either Promaxx (2169) or ATK. Will be in the high 9's for compression. Looking for a cam to get me to 350HP/400TQ. The roller cam they use for that particular 350/400 crate engine is a .495/.502 roller with 220/224 duration @.50 and 112 LSA. I am thinking about the stock ZZ4 cam or the GM Hot cam which is .492/.492. Any thoughts? Torque is way more important to me than top end hp.
Here are the specs:
Block: Seasoned OE 4 Bolt Main 1pc Seal Roller Block P/S Dipstick
Bore/Stroke: 4.040 x 3.480
Displacement: 350 C.I.D.
Crankshaft: OE Cast Crank 3.480" Stroke Externally Balanced Rear/Internal Front 1pc.
Connecting Rods: OE Powder Metal 5.700" Stock Bolts
Pistons: Hypereutectic +6.9cc Flat Top
Piston Rings: Moly Rings
Compression Ratio: 64cc=9.9:1/72cc=9.1:1/75cc=8.8:1
Camshaft Bearings: Installed & Clocked to OEM Position
Freeze Plugs: Brass Installed & Sealed
Oil Galley Plugs: Installed & Sealed
Weight:285
Old 10-15-2015, 02:45 PM
StraubTech
StraubTech's Avatar
The the ProMaxx heads and this cam it makes 415HP/420#ft
.510/.510
280/294
221/235
104/112
108
Heus (10-15-2015)
Old 10-15-2015, 02:57 PM
hugie82
hugie82's Avatar
the tight LSA 108 will give you max torque in a narrow rpm range but it will be an all around good runner.
I'm not familiar with Promaxx but what lift are they limiting their vortec heads at?
Old 10-15-2015, 03:01 PM
StraubTech
StraubTech's Avatar
Power will be within 7% of peak torque for 2000 rpm. Within 10% for 2400 rpm. I don't feel that is narrow.
Old 10-15-2015, 03:12 PM
Karsten
Karsten's Avatar
I bought the HP89 350/375 HP Vortec with the following specs.
Horsepower: 375
Torque: 400 lb/ft
Pistons: Hypereutectic Flat Top
Compression Ratio: 10.1:1 Compression
Camshaft: Hydraulic Roller
Camshaft Specifications: 220/224 @050 .528in/.536ex 112LSA
Cylinder Heads: Pro-Filer Aluminum 64cc/195cc 2.02/1.60
Rocker Arms: Stamped Steel 1.6 Ratio
Oil Pan: OE 5qt.
Weight:350
If you are running an Auto Trans don't forget about a stall converter.
Karsten
Heus (10-15-2015)
Old 10-15-2015, 03:38 PM
Heus
Heus's Avatar
.600 lift here's a link:http://shop.whiteperformance.com/PRO...MX9200-274.htm
Old 10-15-2015, 03:56 PM
StraubTech
StraubTech's Avatar
Originally Posted by Heus
I would have ProMaxx set the heads up not Whites.
Old 10-15-2015, 04:02 PM
76strokervette
76strokervette's Avatar
Chris I have seen the pro-filer video on youtube for the 406,what did it make?
Old 10-15-2015, 04:37 PM
StraubTech
StraubTech's Avatar
Which video sir?
Old 10-15-2015, 05:13 PM
76strokervette
Video is labeled 406 sbc with pro-filer heads from straub technologies made about a month ago.Clip shows 15 second dyno pull.
Old 10-15-2015, 05:32 PM
StraubTech
StraubTech's Avatar
.285/293 @ .006
.231/.239 @ .050
.151/.152 @ .200
.576/.545 lift (with 1.6 rockers)
107 lsa
AED 950 (820) carb
9.9-1 compression
89 octane
HVH spacer
ported rpm intake with divider cut down
headers, probably some kinda 1.75" dyno headers,
6000rpm max
Old 10-15-2015, 05:36 PM
StraubTech
StraubTech's Avatar
512HP at 6000 rpm
535#/ft at 4000
To Cam recommendations for Vortec 350
Quick Reply: Cam recommendations for Vortec 350
