Trans cooler install questions I forgot to ask
Old 08-26-2016, 10:53 PM
Oldguard 7
Oldguard 7's Avatar
Default Trans cooler install questions I forgot to ask
I posted a trans cooler installation thread last week and I forgot to ask the following questions. What type of plugs can I use to plug the trans cooler line openings on the radiator since I'm going to run lines directly from the trans to the trans cooler? What type of plugs have forum members used when installing a stand alone trans cooler?
Old 08-27-2016, 12:53 AM
gkull
gkull's Avatar
Received 1,330 Likes on 1,058 Posts
mine were a NPT brass
Old 08-27-2016, 05:21 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Those would be best...for a radiator with brass side tanks. If they are aluminum, you need to get aluminum NPT plugs.
Or you can go with plastic plugs with an O-ring or rubber seal...anything that will keep water/debris from getting into the side tank.
Old 08-28-2016, 10:09 AM
mrvette
mrvette's Avatar
I just left it open....been that way for years ......
Old 08-28-2016, 11:08 AM
jb78L-82
jb78L-82's Avatar
Go to home depot and get a brass plug that fits or just leave the plastic plug that comes with the radiator in the hole if the radiator is new...Either way it should cost you no more than $3-4 dollars at most at HD.
Old 08-28-2016, 01:56 PM
bluedawg
bluedawg's Avatar
Times 2.
Old 08-28-2016, 03:00 PM
7T1vette
7T1vette's Avatar
Bubba is as Bubba does....
To Trans cooler install questions I forgot to ask
Quick Reply: Trans cooler install questions I forgot to ask
