Spark Plug Gap on a 75 with HEI
Old 10-26-2002, 08:16 AM
MrAzz74
MrAzz74's Avatar
Default Spark Plug Gap on a 75 with HEI
I have a 75 Stingray and was wondering if anyone knew the spark plug gap for that year. I have an HEI which has the Pertronix Flamethrower rebuild kit on it!! I have Bosch Platinum plugs also!! Thanks in advance for any help!!
Joe :seeya
Old 10-26-2002, 08:42 AM
Larry B.
Larry B.'s Avatar
Default Re: Spark Plug Gap on a 75 with HEI (MrASS74)
I believe the early HEI used a .060 gap.
Old 10-26-2002, 09:47 AM
page62
page62's Avatar
My '79 with stock HEI uses a .045 gap.
Old 10-26-2002, 11:24 AM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Spark Plug Gap on a 75 with HEI (page62)
wow - that's a pretty big gap for a stock HEI... I use .045 with 50000 Volt HEI and MSD... Maybe I should increase my gap to .050...
:cheers:
Olivier
Old 10-26-2002, 12:43 PM
pws69
pws69's Avatar
Default Re: Spark Plug Gap on a 75 with HEI (GrandSportC3)
I had a '76 Olds Cutlass once and the gap was somewhere between .060 and .080!! So I would try .060.
Old 10-26-2002, 12:53 PM
joe73vette
joe73vette's Avatar
Default Re: Spark Plug Gap on a 75 with HEI (pws69)
The early HEI's specified a gap of .060", but they had problems with burning thru the rotors after a lot of miles, and the infamous red dust and frozen advance weights. So the later ones were changed to .045". That should work for you. Joe
Old 10-28-2002, 03:46 PM
stingraynick75
stingraynick75's Avatar
Default Re: Spark Plug Gap on a 75 with HEI (joe73vette)
On my 75 I gap them @ .045" because of what joe73vette said, I also noticed that 1975 is the only year for that large of a gap, wonder why :rolleyes:
Old 10-31-2002, 05:24 AM
jackson
jackson's Avatar
Default Re: Spark Plug Gap on a 75 with HEI (stingraynick75)
If you look at GM's specs on CURRENT replacement chevy 350 motors with big cap HEI ... the spec is 0.045".
To Spark Plug Gap on a 75 with HEI
Quick Reply: Spark Plug Gap on a 75 with HEI
