Rear wheel bearing removal
Old 06-24-2003, 09:51 AM
MWLockwood
Cruising
MWLockwood's Avatar
Default Rear wheel bearing removal
Has anyone tried to replace the rear wheel bearing? How does the bearing come off? I am down to the bearing removal. Thanks
Old 06-24-2003, 09:55 AM
tictocdok
tictocdok's Avatar
Default Re: Rear wheel bearing removal (MWLockwood)
depends on whether or not you've got the spindle out of the TA. a couple methods which are sort of a long process to go into here in great detail! do you have a repair manual for your vette?
Old 06-24-2003, 09:57 AM
79VetteMike
79VetteMike's Avatar
What exactly are you trying to do? The spindle has to be pressed or "knocked" out of the bearing housing.
Old 06-24-2003, 11:10 AM
76Stinger
76Stinger's Avatar
This is an Auto Zone website with info. Not specific for vettes but some good general info. Me personally, I gave up the ghost and found a local expert to do my whole rear end. Good luck!
http://www.autozone.com/servlet/UiBr...3d8004fcaa.jsp
STW :seeya
Robert
76Stinger
[Modified by 76Stinger, 10:11 AM 6/24/2003]
Old 06-24-2003, 09:16 PM
GTR1999
GTR1999's Avatar
Received 2,680 Likes on 1,354 Posts
Do a search there have been a lot of posts on rear bearings. I wrote up the procedure a couple of times as has Norval and Tom454. If you need help afterwards IM me and I'll walk you through it.
Gary
Old 06-24-2003, 10:25 PM
Big Fish
Support Corvetteforum!
Big Fish's Avatar
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
These links should help. This is not a job for the average do-it yourselfer:
http://www.corvettefaq.com/redir.asp?site=59 http://www.corvettefaq.com/redir.asp?site=62
Hope this helps!
:D
Old 06-25-2003, 06:08 AM
stingraynick75
stingraynick75's Avatar
Yes, do a search... I recently did a post....."Dont try this at home", which was on rear wheel bearings!!!! I tried and ended up calling a flat bed and spending $250. a side to have it done :eek: but it's a done deal :D
Old 06-25-2003, 06:54 AM
Dalannex
Dalannex's Avatar
Default Re: Rear wheel bearing removal (stingraynick75)
I have done my own bearings. It does take a few specialty tools, and some studying, but it can be done. It certainly is more than your standard wheel bearing though. Here is one archived post with a pic of one homemade tool I used to do mine. You will also need a bearing setup tool, spindle install tool, and magnetic base dial indicator. If you aquire all of the proper tools, and are pretty handy mechanically, you can do it. http://forums.corvetteforum.com/zerothread?id=552878
-Justin
Old 06-25-2003, 11:20 AM
ROD NOCK
ROD NOCK's Avatar
http://www.vansteel.com/index.cfm?fu...bearingremoval
To Rear wheel bearing removal
Quick Reply: Rear wheel bearing removal
