Critters
Old 09-20-2004, 03:43 PM
Jvette73
Jvette73's Avatar
Default Critters
I dont have a closed garage but a carport instead. Either chipmunks or squirrels are getting up under the hood and trying to nest and leaving piles of nutshells on my intake manifold. Any suggestions on how to convince them they dont wanna be there?
Old 09-20-2004, 04:25 PM
COMMANDER370
COMMANDER370's Avatar
Get a dog?
Years ago before i built my shop, my car was left out like yours.had a problem with neighbors kitty sleeping on top of the car. i took 2 large beach towels and placed one on the front and one on the back.i then sprinkled chinese red pepper all over the towels. after the cat walked thru the pepper, he did what cats do and cleaned his paws. that cat could run!! never saw him aroud my car again.
Old 09-20-2004, 04:34 PM
R. Bruno
R. Bruno's Avatar
How about some good old fashion rat traps?
Old 09-20-2004, 04:44 PM
marshrat99
marshrat99's Avatar
Sad to say but rat poison works pretty good.
Old 09-20-2004, 04:48 PM
VettePower
VettePower's Avatar
Get a Gun!!!
Old 09-20-2004, 04:55 PM
oregonsharkman
oregonsharkman's Avatar
may sound stupid but a stuffed cat (not an ex real one ) that looks semi real can act like a scarecrow (scarecat??) to rodents. It worked for mice problems in my garage
Old 09-20-2004, 05:07 PM
R. Bruno
R. Bruno's Avatar
unless they die in your heater vents.
Old 09-20-2004, 06:20 PM
Jvette73
Jvette73's Avatar
We have two indoor cats. I wonder if I used blankets with thier scent on em to surround the area around the car. Might that work? I dont like the idea of them dead from poison and rotting up in my frame somewhere.
Old 09-20-2004, 09:38 PM
R. Bruno
R. Bruno's Avatar
Well, I have a cat and they certainly leave plenty of hair around - worth a try.
Old 09-20-2004, 11:16 PM
rrent
rrent's Avatar
An old trick to keep dogs from piddling on car wheels/tires is to put moth ball crystals in the area -- dogs don't like the smell --- might work with your varmits......
Old 09-21-2004, 02:08 PM
Evil_1979
Evil_1979's Avatar
Default Mothballs all the way!!!
Mothballs may work. Crush up a bunch and put them on the ground where your car is parked (especially under the engine). Maybe even a bag of mothballs under the hood until they decide to leave your car alone.
We use mothballs to keep mice/rats/other critters out of the tack boxes where we keep saddles. Having a $2000 saddle chewed up by a mouse will really get you angry! I have an entire box of mothballs strewn about the floor of my tack box. Never seen a mouse in there since I put them there. Before mothballs- I had at least 3 or 4 in my there every time I opened it.
Cheers!
~Kevin
Old 09-21-2004, 07:14 PM
Jvette73
Jvette73's Avatar
Ok then we will give the mothballs a try. First I'll remove the current evidence by vacuuming up all the piles of nutshells off the top of the engine. When its all clean I'll spread ground up mothballs under the car. If they work it should be easy to tell. The shells will cease to accumulate. It will take some time for results but I'll post back. Thanks for the help.
Old 09-21-2004, 09:56 PM
77BlueL82
77BlueL82's Avatar
Default Irish Spring Soap
I had a rat/mouse problem and used Irish Spring soap in the interior and a piece under the hood. It seemed to work, but I'll neverknow for sure, I found the rat dead on one of the sticky traps.
Old 09-22-2004, 11:22 AM
Go-Gone
Go-Gone's Avatar
The mothballs do work. I put them in a small plastic container and set the container on the manifold. Just dont forget to remove it before you start the car.
Old 09-22-2004, 12:36 PM
mayberg
mayberg's Avatar
The wife's grandparents live out in the sticks. They put the hood up on their cars to keep the rodents out of the engine compartment.
Old 09-22-2004, 03:53 PM
75 Hot One
75 Hot One's Avatar
I tried the mothball route- didn't work on Canadian mice- they left turds all over the intake manifold and chewed into the hood insulation.
To Critters
Quick Reply: Critters
