Procharger Tuning Newbie
Old 07-04-2015, 11:12 AM
oldschool85
oldschool85's Avatar
Default Procharger Tuning Newbie
I recently purchased a 1986 Corvette with a Procharger Model #P600B with larger injectors, Super Ram Intake. Stock Engine
How to make sure a/f ratios are right?
How to Tune this Engine?
Old 07-04-2015, 02:33 PM
tequilaboy
tequilaboy's Avatar
My formula is simple: A drop in fuel pump with a new MAF and an extended range tune from Blowerworks for use with your stock 165 ecm. All your fuel and spark needs in one box.
Wouldn't hurt to add a WBO2 for monitoring purposes, but this is not a necessity.
Update: I saw some photos of your installation with the Vortech f-body elbow and Procharger. Do you know if the car has been converted to S/D (speed density) with a later year ecm? Can you identify the ECM and/or map sensor if applicable? If it still has the 165 ecm, we could always install a slot style maf into the Vortech elbow.
Old 08-30-2015, 02:18 PM
gmjr
gmjr's Avatar
Default prochager tuning tip
I have a 89 vette with procharger tuning was always an issue with the fuel injection went with a blow thru carburetor and a wideband 02 gauge car is much faster and easy to tune
Old 08-30-2015, 02:43 PM
gmjr
gmjr's Avatar
Default built dana 36 holds upwell
I have a built dana 36 in a 89 vette its cyrotreated and well built,I have hundreds of 1.6 to 1.7 sixty foot times with no failures all i do is run a real tight backlash if it gets excessive backlash i wont run it untill i reset it.1989 vette d1 procharger high 10s 131mph street car.
To Procharger Tuning Newbie
Quick Reply: Procharger Tuning Newbie
