Help Diagnosing a knocking sound 94
Ok so Ive been getting this horrible knocking sound which sounded like it was coming from underneath. Sounds like bolts rattle around in a can. I jacked it and did the stethoscope on the oil pan, flexplate cover and cats. Cant seem to pinpoint it. Definitely not on top.
So my Alternator went out and per a suggestion from my brother (backyard mechanic) told me to remove the belt and before installing the new alt. and belt, give the engine a run without the belt.
Ok so I did this and removed the belt and water temp sensor plug on pump. Started it up and noise seems to be gone. Further troubleshooting I plug the sensor back in to pump and noise returns but not as loud.
How to proceed from this point? Think its the pump, MAF?
HELP!!!
I would first check really good all engine accessories as well as the balancer.
Sure it's from the engine? Check out the air pump and the ABS pump to see if anything strange is really going on.
HELP!!!
Is it a Automatic or a Manual trans? Many new to the Corvette family are kind of unaware that the ZF 6 speed is kind of a noisy Transmission. I suspect you have a Automatic because you call out having a Flex-plate cover,
so with that said if you do have a 6 speed does it go away with the clutch in and in gear?
Does it go away with raising Idle just off of base idle.
Oil pressure hot at idle is around 20-22 and cold around 60-70.
It was only doing it when cold and would go away but now all the time. With the belt off it seems less noisy but still can hear it a little. Putting the new alt and belt on today and I'll see what I get.
Where is the air pump or abs pump?
thanks for the responses.
Since the water pump is driven off of the cam could it possibly be the pump or is it farther back, it sounds almost like a small carbon chunk.
We need know a little better were
After thought is the coolant level good, may want to Crack the bleeder on top of water pump just in case you have some cavitation going on
ABS pump runs for few seconds when you first move over 4 mph for the ABS test. It's a onetime shot after starting up and moving and is mounted in the compartment behind the driver's seat. It should not consistently run. Sounds like a ratchet for the test.
I finally got the new alt put in. It's rare that things should be simple. When I removed the old alt, the volt reg. pigtail fell apart so I had to find a new one. Slim pickings down here in paradise. I also purchased a new belt but of course I couldn't get it to fit. I wound up putting the old back on temporarily until I can find the correct one?
The new one looked right but it was just a fraction short and it would not go on.
I checked the air pump and it isn't the sound I was hearing. That is more of a high pitch whine that lasts a minute or so when started. After getting it all back together it hasn't made the knocking noise yet but I haven't run it for any length of time. Kind of odd as it was making it all of the time before hand, even on start up so after this storm passes us I am going to get it over to a mechanic.
Thanks and I'll update as I find out more.
The one that fit is a NAPA Micro-V #060675. The one that was just a hair short was # 060670. the 670 is the one that comes up as the correct replacement and not sure where the 675 comes into play but it worked.
