Strange horn ALARM !!!!!!!
Old 05-11-2008, 11:06 PM
Calderone
Calderone's Avatar
Default Strange horn ALARM !!!!!!!
Today something really strange happened to me !
i was parked,i was buying some drinks and
i came back and i opened the car from outside moving the
power locks,then ....the horn started to BEEP BEEP BEEP BEEP BEEP... i had to disconnect the battery! then i connected it again and the alarm was gone.-
why ? i've never heard anything like that ...
Factory alarm ?????????'
Old 05-11-2008, 11:11 PM
Livin the Dream
Livin the Dream's Avatar
Originally Posted by Calderone
i came back and i opened the car from outside moving the power locks, then ....the horn started to BEEP BEEP BEEP BEEP BEEP... i had to disconnect the battery! then i connected it again and the alarm was gone.-
If you reached through the window and opened a locked door it will do that. have to put the key into the door lock and turn it to silence the alarm
Old 05-11-2008, 11:14 PM
Calderone
Calderone's Avatar
Yes i did that ...
i had the top off,reached thru the window and opened the powerlocks
is that an alarm ? My vette has no alarm.its a 87
tell me more
Old 05-11-2008, 11:15 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
Yes, that sounds like the factory alarm.
As Livin the Dream said, you can't reach in and unlock or open a door like that.
If you lock your door, you must use the key to unlock the door and not set off the alarm.
Old 05-11-2008, 11:16 PM
RollaMo-LT4
tell me more
Your Vette does have an alarm. You just set it off and heard it.
Old 05-11-2008, 11:21 PM
bryantbjb
bryantbjb's Avatar
Yes - factory alarm. You can also turn it off by using the door key and turning it to the right and then left.
Happened to be as well.
Old 05-11-2008, 11:46 PM
Calderone
Calderone's Avatar
wow ..cool
Old 05-12-2008, 01:04 AM
86PACER
86PACER's Avatar
These guys are right. By reaching in and unlocking from the inside, then opening with the outside door handle, the car "thinks" the window was broken out. This is your factory alarm by design. Turn the door key to turn stop the horns.
Old 05-12-2008, 11:06 AM
AGENT 86
AGENT 86's Avatar
Did you read your owners manual ??
Old 05-12-2008, 01:34 PM
xCCTer
CF JASOC Member
Support Corvetteforum!
xCCTer's Avatar
Location: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Old 05-12-2008, 09:56 PM
DanZ51
DanZ51's Avatar
I hadn't owned my '86 for all forty minutes when a friend of ours set off the alarm as we were looking under the hood. I searched the owners manual furiously as my other friend unplugged the horns.
Mr. "roving fingers" denied any wrong-doing....
To Strange horn ALARM !!!!!!!
Quick Reply: Strange horn ALARM !!!!!!!
