driver window has scrapes fix?
Old 05-12-2009, 08:16 PM
mjfox
mjfox's Avatar
Default driver window has scrapes fix?
my drivers side window has a few patterned scrapes
any one know what is causing this.
what new parts in the door will fix this
can the window be polished
all help
appreciated
thanks mike
Old 05-12-2009, 10:10 PM
TLO
Cruising
TLO's Avatar
I have the same issue with the windows on my 93. I believe it is the anti-rattle door window bumpers but this has yet to be confirmed. Check the link below for more information:
http://www.ecklers.com/product.asp?p...2&dept_id=1445
If the scratches are not too deep, they can be buffed out. This page has more info on removing scratches from auto glass:
http://www.ehow.com/how-does_4811213...r-windows.html
Old 05-12-2009, 10:54 PM
tim32920
tim32920's Avatar
I have the same prob on my 92 thanks for the info
Old 05-12-2009, 10:55 PM
TRace8893
TRace8893's Avatar
Hey, I also have the same problem on my 93! Thanks for the info! Not sure why I haven't looked into the problem (oh yeah, I'm busy with school). I'll try to buff them out, however I do think the scratches are a bit too deep. Figure I'd like to know what is for sure doing the damage before I try to fix/replace anything so thanks for the lead.
Old 05-12-2009, 11:04 PM
zr1fred
zr1fred's Avatar
It's usually the pads on the outer door seals that cause the problem. As far as I know the window can't be fixed, it needs to be replaced. For some reason, the newer C4's (90up) seem to have more of a problem with it. I know I've gone through a lot of them on the LT1 cars.
Old 05-12-2009, 11:14 PM
lostnfoundC4
lostnfoundC4's Avatar
Same problem on my '86
Old 05-12-2009, 11:37 PM
engle1147
Support Corvetteforum!
engle1147's Avatar
Both of the side glass on my '89 are scratched too deep for a buff job.
Old 05-13-2009, 12:07 AM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
Same thing on my 93. It must be the anti rattle bumpers, the scratches are right where the front pad is shown in the Ecklers diagram. Thanks
Old 05-13-2009, 12:46 AM
engle1147
engle1147's Avatar
I just got some new ones I'm going to install soon.
the scratches "are" where the rattle felts ride...my old ones are flattened out from age and feel hard as a 2x4 to the touch.
Old 05-13-2009, 08:14 AM
Steve59
Steve59's Avatar
Got them on my 87. Don't know why there aren't any on the drever side.
Old 05-13-2009, 09:52 AM
95BlueBomber
95BlueBomber's Avatar
You are going to need some extra "anti-rattle" in that bad boy with that 383!
Old 05-13-2009, 09:54 AM
TLO
Cruising
TLO's Avatar
Old 05-13-2009, 10:57 AM
flynn508
flynn508's Avatar
probably just havent used the drivers window as much! The felt pads wear out and harden over time, causing scratches. It is a PITA to open up the door panels and change them out, but needed to keep from scratching the glass. This will happen in ANY car over time BTW; my 01 Audi is getting some scratches on the drivers window already.
Old 05-19-2009, 06:43 AM
LBA50
LBA50's Avatar
My '96 has the same issue. Any advice on removing the door trim panel? Most instructions say "lower door glass" first, but it seems like that would simply put the window in the way of where I need to work. Can the glas be moved aside once the trim panel is off? (Obviously, I've never gone into the door before.)
Thanks in advance for any tips.
Old 05-19-2009, 07:45 AM
WW7
WW7's Avatar
I replaced the front one on the passenger side last year, easy fix. Just unbolt the old one and bolt in the new , uses one bolt, and may need to adjust a bit , only took 1/2 hour tops. Driver side may take a little longer, more door parts to remove...WW
Old 05-21-2009, 09:43 PM
RiceBurnerZ07
RiceBurnerZ07's Avatar
Same problem on my '91
Old 05-21-2009, 09:51 PM
bdw18_123
bdw18_123's Avatar
Location: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
This seems to be a common issue. My '93 drivers window has scratches, I can tell it's from the outer window felt seal. The seal is really hard and pieces are broken off that line right up with the scratches. I have new outer felt seals for both doors (original GM parts) but I haven't installed them yet. I may replace the driver's window someday, but I don't plan on doing it anytime soon.
To driver window has scrapes fix?
Old 05-21-2009, 10:31 PM
RLG
RLG's Avatar
I have the same problem on the drivers side.I have new felts to install. Glad I work for a Auto Glass Company.
Be careful with buffing Curved tempered glass, If it gets to hot it will explode!!
Old 05-22-2009, 04:23 PM
TLO
Cruising
TLO's Avatar
I too thought it was my outer door seals and I replaced them on both doors. Took about 45 minutes. I thought everything was golden until I rolled my window back up and it still sounded like nails on a chalkboard. Hence the reason I suspect the anti rattle door window bumpers.
Old 05-22-2009, 06:11 PM
RLG
RLG's Avatar
The bumpers was what I was referring to , the scratches were deep and the same width as the bumpers.
Quick Reply: driver window has scrapes fix?
