OBC help needed 1990 convertible
Old 07-21-2015, 01:49 PM
luvmyc4corvette
luvmyc4corvette's Avatar
Default OBC help needed 1990 convertible
I have the dreaded seat belt/inflatible restraint light problem. I have access to a OBC 2 reader which can reset codes. I just got a adapter cable to allow it to work with OBC 1 receptacles.
My question is where is the OBC receptacle, I went thru the service manual and it was unclear where it's located.
thanks in advance
Old 07-21-2015, 03:34 PM
antfarmer2
antfarmer2's Avatar
I don't believe it will work but look under the drivers side dash. Look on youtube it can be done with a paper clip.
Old 07-22-2015, 08:21 AM
Paul Workman
Paul Workman's Avatar
I'm guessing you're referring to "OBD", yes? Anywayz, the connector is actually attached to the driver's side hush panel, along the bottom edge near the corner - about where your right knee is.
I don't believe an OBD-2 scanner is going to work, far as resetting codes, etc., unless it has dual (OBD-I & OBD-2) capabilities (as some - like mine - do). But, un-plugging one of the battery terminals for 30 seconds or so will reset ALL of the codes (and radio pre-sets too).
Old 07-22-2015, 04:13 PM
THE 383 admiral
THE 383 admiral's Avatar
OBD2 specific scanners will not connect!! you will need a OBD1 scanner. Or the free paperclip/shortout terminal method. Or 2nd free option pull a cable from the battery that requires radio and or other memory re-sets.
Old 08-06-2015, 09:16 AM
luvmyc4corvette
Unfortunately you were correct my OBD2 didn't work. I am borrowing a OBD1 from a friend.
thanks
Old 08-06-2015, 09:33 AM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
thanks
I don't believe the SIR (MY '90) can be done with any scanner. I don't recall there being any procedures in the '90 FSM for even the Tech1. I believe all of the diagnostics and code clearing is done through the ALDL with jumpers and resetting grounding through the ALDL to good known chassis grounds.
The '90 DERM was a 'one year' only and I don't believe that any of the later adapters etc. were ever stated as being capable or compatible to do SIR for a '90.
** I believe the later Tech1 cartridge and a specific adapter will do a '90. I researched this I believe several years ago and don't recall some of it but here's a link to my comments at the time. Are they correct? I've never tried to do a '90 with the adapters and cartridge mentioned.
http://zr1.net/forum/showthread.php?t=19070
To OBC help needed 1990 convertible
Quick Reply: OBC help needed 1990 convertible
