Quote for 383 LT4 (550HP)
Old 04-20-2005, 11:44 PM
phxscooby101
phxscooby101's Avatar
Default Quote for 383 LT4 (550HP)
http://www.beckracingengines.com/ 383 street kill LT-4
Ok Everyone here is the engine break down: Cost 9,999.00 for a
383 LT4 engine
Scat 6in 4340 connecting rods w arp caps screws bolts
Scat large radius crankshaft
SRP/Je forged pistons
childs/albert z-gap ring set
Clevite 77 h-seris main&rod bearings
dura-bond cam bearings
fel-pro performance head gaskets
" " Rear main seal
" " blue steel core v/c gaskets
GM LT4 performance intake gaskets
GM red Lt4 intake manifold
GM lifters bars& spider
Gm rear main seal adaptor, bolts& gaskets
Gm Aluminum front cover, bolts & gaskets
water pump& oil pump drive assemblys
Crane cams hydraulic roller cam & lifters
Cloyes true roller timing set
ARP chrome moly main & head bolts
ARP chrome moly 7/16 rocker arm studs
Arp oil pump stud
Arp 12pt stainless intake bolts
Arp 12pt stainless valve cover bolts
Air Flow Research reverse flow LT4 Aluminum heads w/ bronze guides&
perimiter valve cover bolt holes
Air Flow Research Guide plates
Air Flow Research Rev kit
Comp cams stainless roller rockers
Manley 1pc chrome moly pushrods
Manley chrome moly retainers
Manley spring cups
Crane cams dual valve springs
Crane cams machined steel valve locks
BRE 2.055 & 1.600 1-pc swirl polished
stainless steel valves
BRE teflon pc seals
BRE polished aluminum valve covers w/ baffles & BRE logos
BRE seasoned /selected 350 4-bolt LT1 block
BRE brass freeze plug kit & oil pan bolts
BRE flexplate
Canton oil pan & pick up tube
Melling hi-volume oil pump
Melling steel collard oil pump drive shaft
LABOR:
Removeall cam bearings, freeze & gallery plugs
Thermal clean block
Magnaflux block
Tap all bolt holes
Clearance block for 6in rods
Stage II debur block
Align hone mains
Surface block square w/ BHJ index fixture 90 degrees
Bore cylinders 90 degrees to deck
Hone block w/ BHJ torque plates
Platue hone cylinders
Install cam bearing
File fit z-gap rings
Side clearance rods
Pinfit pistons & rods
Balance assembly
Micropolish crankshaft
Install pistons on rods w/ spirolox & Align
Radius seat performance valve job
Stage V port heads
Hone guides for fit
CC heads
Surface heads
Port & Polish intake manifold
Assemble Longblock
Degree camshaft
Blueprint oil pump
Weld pick up tube to pump & set clearance
Install Manifold & accessories
Thats everything.
Now I want to know if this is a good deal??
Estimated HP is 550 hp 5800rpm and 537tq 4900 rpm this is on a engine dyno.
Too me this HP figure sounds high but I am not sure.
Also a turn key package costs 11,899.00 which includes the above plus
Champion race spark plugs
Aeromotive adjustable regulator
ASM 58mm billet throttle body
FMS 42# injectors
Any input from you guys would help a lot, Thanks Chad
Old 04-20-2005, 11:57 PM
JAKE
JAKE's Avatar
What block are they using, or did I miss that?
Jake
Old 04-21-2005, 12:02 AM
JAKE
JAKE's Avatar
I really appreciate the time it took you to post all those specs, but you know what I'd do?
I'd grab myself three or four catalogs, Summit, Performance Automotive Warehouse, JEGS, etc., and sit down and price each and every part they're supplying and then do the math.
From that you can see how much they're charging for labor/profit. You'll also be able to see whether it's a "deal", reasonable or whether you're gettin' hosed.
Jake
Old 04-21-2005, 12:03 AM
bogus
bogus's Avatar
and the RPMs, low... LT4s redline at 6300 or so.
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
If they are useing the Crane Cam equivelant to the GM 847, you are about 30 hp off, but I know Crane has other cams. It is just that the cam is popular
Old 04-21-2005, 12:05 AM
JCD
JCD's Avatar
If they do everything that's on the quote, I would think that would be a great deal. Do they dynotune it also?
Enjoy destroying your transmission!
Old 04-21-2005, 12:11 AM
phxscooby101
I think alot of the cost is what they do in house which is everything needed for the block, CNC machine, Honing, flow machine, etc they have everything to build a motor correctly.
What I am not sure about is the HP #. He says they regularly tune and dyno the engine at ADS here in Phoenix.
From my research here on LT4 motors it is pretty hard to get 450 to the ground naturally aspariated.But he has been building Race motors for 20 years.
Do you all think the HP is acheiveable assuming an aggressive cam and the parts listed?
Also he said it was in the 10.2 compression range for our 91 crap gas.
Thanks Chad
Old 04-21-2005, 12:12 AM
FD2BLK
FD2BLK's Avatar
That is a good price, If I where you I would contact More performance just so you have more then one point of refernce. It sounds like you are on the right track
Old 04-21-2005, 12:13 AM
phxscooby101
He is in the process of getting his engine dyno up and running, but I do know the spec everything and I'll find out if they dyno the engine and prove the HP rating. Chad
Old 04-21-2005, 03:41 AM
JAKE
JAKE's Avatar
The machine work should only involve doing the block and that shouldn't even amount to $500. The crank, rods and pistons should be new and need no machine work.
My gut tells me it's NOT a good deal; but I've got the sense that's not what you want to hear. Once you add up the cost of the parts and post the sum, we'd all know more about what they're making on that package.
To me, ten thousand dollars for a 383 isn't a good deal. For a 540 or 555 Big Block I'd say YEA!, but not a little 383.
550 Hp out of a 383 calls for around 1.44 HP per cubic inch. Normally aspirated, you're not going to get that much unless the engine is extremely radical. Again, I suspect that's not what you want to hear.
What about ignition and carb/FI?
All I can suggest is Be Smart and do your homework before deciding to plop down your money.
Jake
Old 04-21-2005, 04:02 AM
REDC4CORVETTE
REDC4CORVETTE's Avatar
I have the same set up and have 14 thousand in it and it only makes a little over 438 hp.
Which AFR heads I have 220 and 11 to 1 pistons.
I CAN"T use guide plates and had to use shaft rockers to the tune of $1,100.If I had it to do over, I would have gone with a 434.
They make one that will fit in al vet.
Old 04-21-2005, 06:32 AM
FD2BLK
FD2BLK's Avatar
I have 7K in my motor and I built it my self so the price quoted for a 383 LT1 w/AFR heads is not a bad deal. More Performance gets 10K for there package and LPE is around the same. Another point as I stated earlier with a little higher CR then my set up and a bump up in cam size 550 FWHP is not going to be a problem, again its done every day. My set up is 10.7:1, and a fairly small, for a 383, cam and I am right at 500 FWHP. Again if you want an idea of what these combos will make in terms of FWHP/TQ give a couple of other know vendors a call such a LPE or More. If you plan carefull and make sure you choose a combo where all the parts work togeather the LT platform will make serious HP/TQ and still be compleatly streetable. Again the 10K is not just for the parts (Around 7K same as my motor), but also for the experience of the builder. RED, I feel for you, I f I spent that kind of $$$$ and the motor didn't perform as the builder stated I would be steamed but not all builders are the same, I aounder about the choice of heads for your combo they seem a bit big I would have went no bigger then the 210's. The reason I build my own motors is because I am a PITA to deal with as a customer and tend not to trust anything unless I see it done or do it my self. One last note The machine work with splayed mains will be a lot more then $500 with ballancing, deck work ect..., (Ask me how I know). Good luck and again it sounds like you are realy doing your home work.
Old 04-21-2005, 08:50 AM
luvmy92
luvmy92's Avatar
Jake
Hmmm...
Machine Work
Surface block and square deck.........................$175.00
Bore and hone block................................... ....$200.00
Check rod small end and true as necessary..........$28.00
Check pin fit in piston and true as necessary........$32.00
Balance crankshaft.............................. ...........$195.00
Deck heads................................... ..................$70.00
Rough in and align/hone main caps.....................$350.00
Balance flywheel and clutch...............................$55 .00
Strap front cap..................................... ...........$30.00
Wash block and install cam bearings....................$78.00
Machine Work labor:.................................. ...$1,213.00
Well I got taken to the cleaners then.
Mike
Old 04-21-2005, 02:03 PM
FD2BLK
FD2BLK's Avatar
Originally Posted by luvmy92
Hmmm...
Machine Work
Mike
And that is W/O Splayed mains, You can get a block hot tanked and bored for less the $500 but for any motor that is going to be 400+HP it should be Decked and the Mains align honed. To do a bolck right it is normaly 1K plus.
Old 04-21-2005, 02:12 PM
luvmy92
luvmy92's Avatar
I bought 4-Bolt billet caps for the 3 middle main caps, but they are not splayed.
Mike
Old 04-21-2005, 02:21 PM
GeosFun
GeosFun's Avatar
The quoted price is very simlar to price charged by Golens Engines for a similar 383, L-98, turnkey w/dyno testing (I think 460Hp, 500+ torque). Golens also builds LT-4's but I did not check those prices. Parts is parts, so to say. Sounds "in the ballpark" and competitive to me. The differences in HP will be in cam profiles, compression ratios, head porting, etc.
Old 04-21-2005, 03:41 PM
FD2BLK
FD2BLK's Avatar
Mike
Also a strong combo just a little less for the machine work then the splayed. I want to say all said and done it wat $600 extra for the splayed work including the line bore
To Quote for 383 LT4 (550HP)
Old 04-21-2005, 03:52 PM
Hammer
Support Corvetteforum!
Hammer's Avatar
Looks fair, I will try and post mine when I get home tonight.
~$12k with AFR 220's. from www.race-prep.com
Old 04-22-2005, 09:45 AM
phxscooby101
ttt
Old 04-22-2005, 04:37 PM
JAKE
JAKE's Avatar
Hmmm...
Machine Work
Mike
He won't need all that because all of his parts, except the block, will be NEW. For 10 grand they'd better be!
Since they're claiming this to be a selected block, I'm thinking he'll only need machine work on the block:
Cleaning,
Bore/Hone,
Decks checked and
Line hone checked.
The remainder of the work, like installing cam bearings, etc., doesn't come under the heading of Machine Work.
Jake
Quick Reply: Quote for 383 LT4 (550HP)
