1990 Seat belt help
Old 02-14-2008, 02:23 PM
jorgito
jorgito's Avatar
Default 1990 Seat belt help
With the drivers side seat belt pluged in, the seat belt dash light indicator stays on. The switch in the seat belt buckle checks ok. What else could I look for?
Old 02-14-2008, 09:03 PM
Yellow2015
Yellow2015's Avatar
Check the wire coming out the bottom of the latch. You might be able to get at it by moving the seat completely forward.............
Old 02-14-2008, 09:34 PM
carson
carson's Avatar
My 90 does the same thing. Have not really thought about it.
Old 02-14-2008, 10:07 PM
pipe
pipe's Avatar
Question for you guy's Is the INFL REST light lit in the drivers info center? or is the bulb burnt out or removed to mask the problem? Only 1990s have this problem. Pipe
Old 02-15-2008, 06:30 AM
mseven
mseven's Avatar
I agree w/the above, mine did that w/out the "INFL REST" on. You can check cavity K (SIR) to see if it threw any realated code/s.
Old 02-15-2008, 11:58 AM
kmillar
kmillar's Avatar
Default Seat Belt
Had the same problem on mine. Check you FSM to trouble shoot, if I remember correctly I had a bad right frame rail sensor that was setting off the code.
Old 02-15-2008, 03:42 PM
pipe
pipe's Avatar
Kmillar could be right. Alot of guy's will pull the Bulb in the DIC to hide the problem. My right front frame rail sensor was the culprit also. See if the car throw's any codes. The frame sensors are only like $60 bucks and an hour worth of time to fix. Pipe
Old 02-15-2008, 03:55 PM
Dr. Evil
Dr. Evil's Avatar
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
This is the problem, I'd bet money on it.
Old 12-27-2013, 12:52 PM
bigj177
bigj177's Avatar
where on the right side of the frame rail is the sensor
Old 12-27-2013, 03:46 PM
DanielRicany
DanielRicany's Avatar
I believe that the seat belt light is computer controlled, or relay controlled. Typically, you will have a power wire, and a ground wire, one or both should go to the computer, or relay. When you put the seat belt into the buckle, it should complete the circuit and let the computer know that the seat belt is connected. Then the computer would turn off the seat belt light. Or if it was a relay, when it is connected, the relay will power up and disconnect the seat belt light circuit from inside the relay. I would do more research on it if I were you, but I think that's how they work.
Old 12-27-2013, 07:26 PM
bigj177
bigj177's Avatar
i figured out my problem, it is a broken wire on the driver side latch
Old 04-03-2014, 03:03 PM
dvanloon
1st Gear
dvanloon's Avatar
There are two frame mounted sensors for the 1990 air bag. The left front sensor is on top of the frame beneath the battery. The right front sensor is on top of the frame beneath the A/C blower assembly. Access to either requires you remove the front wheel and the inner fender panel.
Old 04-03-2014, 04:05 PM
Race Prepared
Race Prepared's Avatar
Sometimes it is the simple solution to fix the problem, as in this case.
Old 04-03-2014, 09:35 PM
ozzyrulesme
ozzyrulesme's Avatar
It's right under the ac/blower motor. Yellow wire going in to a square black box. 2 blots holding it down.
I just replaced my sensor and took care of both idiot lights. They don't sell new sensor for the 90 any more. I took a gamble and bought one off eBay.
To 1990 Seat belt help
Quick Reply: 1990 Seat belt help
