C4 1992 Power locks not working
Hello,
I have a 1992 LT1 6sp and a brand new Z06.
I went to a shop to have the rear antenna of my 1992 replaced. They did the job and then the inside commands for the power locks, on both doors do not work anymore. Aside from that, I have also asked them to install the anti rattling kit for the windows I bought at Corvette Central.
The motors of the power locks are working because the car has an alarm that locks the doors. However, it does not work anymore from the inside.
We have taken the central piece of the doors and made sure that it was connected, they were connected. The guy said it was the only way to connect them.
I've tried to find the fuse boxes for the power locks on the user manual, without success. There is a picture on page 234 that shows an auxiliary fuse box which has the power locks fuse but I could not find it. It says under the hood. The fuse box I know is on the right side of the dash.
So the power lock buttons on the inside of the doors do not work anymore, I can only lock the doors with the remote from the after market alarm the car has.
Can anyone help me with this?
Thanks a lot!
Scheidecker
Thanks a lot!
Scheidecker
Former Vendor
If you remove the area that holds your power door lock switches and the orange wire should have 12+ power going to them. If you have power going to them than more than likely one if not both switches are bad. They are not that expensive and easily changed. I am not at work now and would have to look at my wiring diagram to verify which fuse it is that controlls them or if they are controlled by the CCM/BCM. Hard for me to remember everything. Check the orange wire on both switches and let me know what you have found.
"DUB"
"DUB"
Fuse
Hello,
Thanks a lot!
Scheidecker
Thanks a lot!
Scheidecker
The fuse is under the dash on the passengers side. Remove the under dash panel and there are two fuse holders. 4 fuses per holder, one of them is for the power door locks. The fuse layout is in the owners manual or the FSM.
Great message, yes the two fuse holders are under the kick panel, be sure to take all three screws out. there is one way on the right side, to get to it you need to take off the cover plate for the main fuse panel, the power door lock fuse panel is facing downwared and you really have to get down there to see it. My fuse was blown, why GM put it ther is crazy. Thanks for leading me in the right direction.
I found the blue 15A Power Door fuse under the dash on the passenger side, and it was blown. I replaced it, but the door lock sliders only move a fraction of the full travel that they should.
Does that mean the Power Door Lock Actuators may be seized?
Also, the door keys don't seem to lock the doors, again because it seems they don't move the full swing.
Are there any aftermarket sources for theses Power Actuators? I don't see them on RockAuto or the Mid America M/W catalog.
Thank for the help.
Thank for the help.
YES...the actuators are or possibly BAD...and if you are not getting enough movement...it can be due to the actuators being bad and you are fighting against them when using the key.
Remove the linkage to the actuators and see what happens. It is a process of elimination. I am not there to see what it happening....or how the door key feels when locking and or un-locking the doors.
I like using DORMAN actuator's...they move very freely and smoothly and on a C3...that is REALLY important due to you can twist the lock cylinder in the door due to a binding door lock actuator.
DUB
DUB
1 Post
Thanks ahead of time, I searched for the stupid fuses for awhile before i read this post, thank God for the forums
Navigator
Mike
