Removing Upper Control Arm Bushings
Old 04-03-2012, 09:19 AM
AGENT 86
AGENT 86's Avatar
Default Removing Upper Control Arm Bushings
Doing my front bushing install and I thought I would pass on what worked for me.
I have read about using a press or drilling out the bushing and pulling out the sleeve.
After cutting the shoulder off bushing using a lubed zip blade, I drilled around the bushing to relieve tension. I then lubed my awl and slid it between the bushing and arm. Took my spray lube (has a thin tube nozzle) and injected some in the gap created by awl. Did that at 90* positions.
Using vise grips, I grabbed the inner sleeve and rotated the whole bushing to spread the lube, then twisted the whole bushing out.
Took less than 5 minutes a bushing.
Old 04-03-2012, 11:18 AM
caddyboy84
caddyboy84's Avatar
Nice job, you're quite the Mcgyver That's probably easier than a press, it looks like those control arms wouldn't agree with a press.
Old 04-03-2012, 12:35 PM
AGENT 86
AGENT 86's Avatar
I have a press at work, but this worked so easily. Probably would have spent more time to look for something to make a brace so I could press them out.
The GF calls me McGruber
Old 04-03-2012, 01:11 PM
USAsOnlyWay
USAsOnlyWay's Avatar
Looks way easier.
If you still are doing these, can you tell me what the inner diameter of the arm is?
Old 04-03-2012, 01:12 PM
USAsOnlyWay
Old 04-03-2012, 01:26 PM
caddyboy84
caddyboy84's Avatar
In the past, I've used galvenized plumbing nipples and large sockets with my press.
Old 04-03-2012, 01:44 PM
Crepitus
Crepitus's Avatar
Thanks for passin that on
Old 04-03-2012, 03:14 PM
AGENT 86
AGENT 86's Avatar
Originally Posted by USAsOnlyWay
Looks way easier.
Just did them yesterday, so your in luck. Going golfing, but will measure when I get back.
Old 04-03-2012, 04:01 PM
USAsOnlyWay
Great thanks! Try to keep it in the short stuff.
Old 04-03-2012, 11:21 PM
AGENT 86
AGENT 86's Avatar
Looks way easier.
1.478" and 1.358"
Old 04-04-2012, 04:13 AM
USAsOnlyWay
Thanks so much, that saved me some trouble!
Old 04-04-2012, 04:22 AM
slickfx3
slickfx3's Avatar
wow
Old 04-04-2012, 06:28 AM
blackozvet
blackozvet's Avatar
they are a bugger to get out arent they !
here's how i got my new ones back on,
Old 04-04-2012, 11:11 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
I already had this tool, http://www.harborfreight.com/four-wh...-kit-4065.html so I used it, works great but Dan's method is a lot cheaper. Can't beat this tool for u joints though.
Old 04-05-2012, 03:44 AM
Cliff Harris
Cliff Harris's Avatar
I need to do that. Got the new bushings sitting on the shelf in the garage. I guess fear of the unknown is holding me back. I've never taken apart the front suspension. I'm afraid I'll get it apart and not be able to get it back together.
Old 04-05-2012, 07:28 AM
AGENT 86
AGENT 86's Avatar
Mine sat on the shelf for 6 years, always found a different winter project.
Nothing to fear here, get out there and do it.
Old 04-05-2012, 07:32 AM
AGENT 86
AGENT 86's Avatar
That looks like something I could use at work
Better let my boss know
To Removing Upper Control Arm Bushings
Old 04-05-2012, 01:04 PM
DanZ51
DanZ51's Avatar
i think mine where on my shelf even longer.
Interesting method Dan used. I used my HF press-of-love. The support for the A-arm was a piece of angle iron cut to length; 'worked great and stayed in place.
Old 04-05-2012, 01:41 PM
jhammons01
jhammons01's Avatar
86, I wasn't going to click until I saw it was your thread.....
Old 04-06-2012, 12:49 AM
Cliff Harris
I saw "somewhere on the Internet" where a guy used the back of his vise and squeezed the A arm between the vise and the wall. I tried that when I was rebuilding my 700r4 and ripped my workbench off the wall. It's a lot more robust now...
Quick Reply: Removing Upper Control Arm Bushings
