Need a new fuel pump
Old 06-30-2014, 05:05 AM
boxer141c
boxer141c's Avatar
Default Need a new fuel pump
Need a new fuel pump for a 1984, anyone have a preference? Where can should I order it from? I read somewhere to replace it with an 85 fuel pump.
Old 06-30-2014, 08:15 AM
davewhtt
davewhtt's Avatar
I used Rockauto for my 93. You can get a acdelco for under 50$ or bosch for a little more. Dont forget to change sock. Not a bad job. Dave
Old 06-30-2014, 09:35 AM
GKK
GKK's Avatar
Delphi, from RockAuto!...
Old 06-30-2014, 09:50 AM
Annoyed
Annoyed's Avatar
Is your engine stock or modified?
Here's what I bought and installed in my '85 C4 LS1 (roughly 325hp)
http://www.ebay.com/itm/300937556449...U:3160&vxp=mtr
255lph, quiet, complete (kit), delivered to your door for just $50USD.
Only thing, you'll have to modify a couple wires because the plug wouldn't fit into the original.
(In case you don't know: First make sure that it's okay for your C4 to be pumping out 255lph out of the tank to your engine. There's a rule-of-thumb formula out there [which I can't remember.. something about 30% max] about calculating fuel volume to horsepower... gotta make sure it's not pumping too much fuel otherwise the fuel heats up and your engine detonates...)
Old 06-30-2014, 12:02 PM
N42375
N42375's Avatar
My 90 coupe also needs a fuel pump. I'm buying a Delphi from Rockauto. $52.79. PN# FE0110. Strainers from $3.50 to $5.20. You can get a 5% discount by using the code on their website. The fuel tank gasket seal is a Bosch PN# 68238 for $11.57.
Old 06-30-2014, 01:16 PM
playsdixie
playsdixie's Avatar
when you take it out, and see how nasty the sending unit is too, you'll want the whole thing...corvette central has a nice stainless complete..pump is not as good as those walbro 255's...
Old 06-30-2014, 05:47 PM
boxer141c
boxer141c's Avatar
Looks like I am going with Delphi. My vehicle sometimes hesitates when accelerating from a stop and after I take it for a drive and it heats up it stalls. I can start it right back up but it keeps stalling until I let it cool down. I assumed it was a fuel pump issue. What do you guys think? Its a stock motor
Old 06-30-2014, 05:54 PM
boxer141c
boxer141c's Avatar
Also will the 1985 Corvette Delphi fuel pump fit the 84?
Old 06-30-2014, 07:09 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
My belief is that it's not the pump. You can go to any parts store and get it. Nothing special about it
To Need a new fuel pump
Quick Reply: Need a new fuel pump
