Camaro 700R4 - Same TV Cable?
Old 09-18-2014, 12:13 AM
Jinxie
Jinxie's Avatar
Default Camaro 700R4 - Same TV Cable?
I will be installing a 89 Camaro 700R4 in my 85 Vette in place of the failed 700R4. I plan on changing the output housing and cutting the tailshaft 5/8" so it will fit.
Do I have to worry about the tv cable? Will the one from the 89 Camaro work in the corvette?
Old 09-18-2014, 02:24 AM
WVZR-1
WVZR-1's Avatar
Received 2,263 Likes on 2,026 Posts
The TV cable is different for the '85 Corvette. The TV cable from the Camaro would be the same for the '89 - '91 Corvette. You need a GM # 25521263 or use your old one, it's the same as the '85 - '88 5.0F and the L98 Camaro if you have access to any more.
Quick Reply: Camaro 700R4 - Same TV Cable?
