Motor just cuts off!! Help
Ok I got you attention, I can start and warm up the car, I can drive it until I come to a stop then it will idle fine and just before or just as the light changes it dies. I place it in park and it starts right up, HELP I am stumped
First check your fuel pressure. You will need a FP gauge.
Possible weak fuel pump or bad strainer\filter.
you could have a ignition module failing. Any codes?
