Question about setting new idle speed with Tuner Pro
I wanted to lower my in gear idle rpm from 825 to 775 rpm on my 89 because the car was pulling at traffic lights with the brake pushed , and as soon as I let off the brake the car would move forward... (Im using Tuner Pro)... I went into (rpm vs coolent temp), and changed the rpm on the scale from 825 to 775 , I did this on all the temp numbers from 154 degrees up to 300 degrees...I left the other numbers alone..Is this the proper way to change the idle speed and did I change the rpm in the proper scaler.????? Thanks WW7
