Removing TV cable
No. There is a linkage inside the pan at the TV Valve that needs to be disconnected.
edit: at least on a 700r4.
C4vettrn (09-11-2015)
Yes.
First, remove it from the throttle linkage. Then remove the bolt that holds the cable to the case. There will now be enough slack to disconnect the cable and remove it from the linkage at the trans.
When I get the trans back from RPM will I need to drop the pan to install the cable or can it be maneuvered into place the came way? Odd the manual doesn't cover this, Thanks!
There's a wire linkage that comes up through the hole in the case. With the throttle body side of the cable disconnected, it should just slide right back onto the linkage without removing the pan.
Be sure you get the cable adjusted correctly. It'll kill your trans if you don't, and they probably won't warranty it.
