'94 Hood Release Handle Mounting Location
Old 01-29-2016, 06:43 PM
Max Austin
3rd Gear
Max Austin's Avatar
Default '94 Hood Release Handle Mounting Location
Bought my corvette with a broken hood latch cable and disconnected hood release handle. I've replaced the cable. I have the hood release handle and the bracket it is connected. I can't for the life of me find the spot that the bracket mounts to under the dash. I've removed the panels and just can't feel or see a spot where the bracket (with to bolt holes) mounts to.
Has anyone done a handle replacement before?
Old 01-29-2016, 07:52 PM
pcolt94
pcolt94's Avatar
If you look at the driver kick panel on the left you will see a rectangular opening. It goes behind there on the frame. You have to remove the kick panel to see the mounting area behind it.
Old 01-29-2016, 08:06 PM
WVZR-1
WVZR-1's Avatar
Received 2,263 Likes on 2,026 Posts
From a '96 FSM
Name:  HOOD LATCH.png
Old 02-01-2016, 04:53 PM
Max Austin
3rd Gear
Max Austin's Avatar
Thanks for the replies. I've got the handle (7) attached to the mounting bracket (3). I've removed the panels underneath the instrument console. I just don't see any spot on the frame to mount the bracket on. I've attached a picture of where I think it should go but there's no bolts or holes for the two bolt hole bracket (3). Could I be missing something?
Old 02-01-2016, 05:03 PM
antfarmer2
antfarmer2's Avatar
I believe it bolts to the bottom of the dash stand on you head and look up.
Old 07-05-2017, 04:12 PM
bobbydrus76
3rd Gear
bobbydrus76's Avatar
have the same problem took panels off and nothing there is more then take rectangular panel off theres nothing to see except more dash
Old 07-05-2017, 06:50 PM
Max Austin
3rd Gear
Max Austin's Avatar
I figured it out. It connects to that rusty bracket in my picture (previous post), not the dash. It's weird because the rusty bracket isn't actually connected to the dash, I think it was actually connected to the clutch pedal apparatus or something strange like that. Can't remember exactly.
You need to buy some threaded connections (not sure what they are called). They slide over the holes in the 'rusty bracket' so you can bolt the hood release cable bracket to it.
Old 07-06-2017, 01:37 PM
bobbydrus76
3rd Gear
mine is a 96 the hood release handle hangs seen a bracket on ebay I don't think mine mounts like that cant see or feel and way this mounts may be gone but trying to get info online is useless ty
To '94 Hood Release Handle Mounting Location
Quick Reply: '94 Hood Release Handle Mounting Location
