Headlight Motors
Old 01-02-2003, 03:14 PM
choirboy
2nd Gear
choirboy's Avatar
Default Headlight Motors
94 coupe with headlight motors that run for up to 5 seconds following turning on or off headlights and headlights are in stored or operating positions. Is this normal or am I in danger of damaging motors?
Old 01-02-2003, 03:34 PM
VetBoy89
VetBoy89's Avatar
Default Re: Headlight Motors (choirboy)
Sounds like your bushings are bad.
Go to http://www.ecklers.com and order two sets of 29304 (one for each side, you may as well do both at the same time). They are $5 a set. There is a tech tip here on the forum that will ease the installation.
Mine was doing the same thing and after the bushing install they were back to normal.
BTW, welcome to the Forum! :seeya
:cheers:
[EDIT] Here is the link to the tech tip: https://www.corvetteforum.com/techti...D=16&TopicID=2
[Modified by VetBoy89, 12:36 PM 1/2/2003]
[Modified by VetBoy89, 12:37 PM 1/2/2003]
Old 01-02-2003, 03:50 PM
don hall
don hall's Avatar
It would appear that you might have a faulty Headlight Control Module, or a faulty Relay coil.
..... am I in danger of damaging motors?.......
I'm not sure, but it is not a healthy condition. It should be corrected.
Old 01-02-2003, 07:19 PM
jackdaroofer
Support Corvetteforum!
jackdaroofer's Avatar
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Headlight Motors (VetBoy89)
:cheers:
:iagree: Go for the bushings. I don't believe relays come into play at all. There is an electro/mechanical circuit that shuts the motor down when it senses the pressure from the lights being open or closed.
Bad bushings delay this action
:steering:
To Headlight Motors
Quick Reply: Headlight Motors
