Antenna Mast
Old 07-06-2003, 07:41 PM
FussBudget
FussBudget's Avatar
Default Antenna Mast
I am trying to replace my antenna mast. I removed the nut on the mast but can not seem to pull the mast out with moderate force. Any ideas?
Old 07-06-2003, 08:29 PM
AGENT 86
AGENT 86's Avatar
Default Re: Antenna Mast (madmanjim)
Did you remove the bolts that hold motor body to the car? :cheers:
Welcome to the forum !! :seeya
Ah I see you meant just the ribbon !!
[Modified by AGENT 86, 8:56 PM 7/6/2003]
Old 07-06-2003, 08:40 PM
FussBudget
FussBudget's Avatar
Default Re: Antenna Mast (AGENT 86)
No. From what I understand, I take the one nut off the top surrounding the mast, turn on the radio, and the mast should slide up and out....
Old 07-06-2003, 09:36 PM
NOT-MEE
NOT-MEE's Avatar
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
turn on radio pull on it on the way up it should come out i did mine a few weeks ago the gm mast came with a tool to remove the nut under the body grommet.did to go up farther than usual or is it still in the stock postion.if it is still in the stock postion it sounds like thier is makbe a pice of the nut still on mast tube.
Old 07-06-2003, 11:42 PM
Siveck
Siveck's Avatar
Default Re: Antenna Mast (crash1mac)
Pull harder. I f the nut is off and the radio is on, it will come out with a little force. You might want to pull the motor cover off and check for loose fragments before installing the new mast.
Old 07-07-2003, 02:09 AM
Corvettehumlan
Corvettehumlan's Avatar
https://www.corvetteforum.com/techti...D=17&TopicID=2
Old 07-07-2003, 02:11 PM
Ray Quayle
- 1986 Original Owner -
Support Corvetteforum!
Ray Quayle's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
This guy didn't say and nobody asked, but year is important. The mast is only replaceable on '88-'96.
Just a note.
To Antenna Mast
Quick Reply: Antenna Mast
