a/c went out and light flashes!! WTH?
Old 12-09-2003, 11:05 PM
GRNVNM93
GRNVNM93's Avatar
Default a/c went out and light flashes!! WTH?
My a/c wentout today, haven't been using it much lately, as it's kinda cool... So I went to use the a/c today and I pushed the button(electronic air) and the green light just flashes off and on and the compressor never even kicked in. Would this be a problem with the compressor or the electronic control unit??
Old 12-09-2003, 11:10 PM
SPEED750
SPEED750's Avatar
Default Re: a/c went out and light flashes!! WTH? (GRNVNM93)
I think you might be low on freon. The flashing light is a safety signal that your AC has a problem.If you have low freon pressure your compressor won't kick on. :chevy
Old 12-09-2003, 11:18 PM
GRNVNM93
GRNVNM93's Avatar
Default Re: a/c went out and light flashes!! WTH? (SPEED750)
Wow, that makes sense.. Thanks for the info. I'll see what I can get done for this.
Old 12-09-2003, 11:22 PM
GRNVNM93
GRNVNM93's Avatar
If i'm low on freon, doesn't that mean there is a leak somewhere in the system? And if so, where would those places prone to leaks be?
Old 12-09-2003, 11:43 PM
belmor
belmor's Avatar
could be a leak, there can be many places it can leak:bad lines, bad compressor seals or bearings, or loose connections-best to have some dye put in when you recharge it and check it
Ben
Old 12-10-2003, 09:11 AM
Steel Blue 91
Steel Blue 91's Avatar
Default Re: a/c went out and light flashes!! WTH? (belmor)
You can pull the trouble codes for the system. Here's a link to the tech tip that tells you how:
https://www.corvetteforum.com/techti...=193&TopicID=2
To a/c went out and light flashes!! WTH?
Quick Reply: a/c went out and light flashes!! WTH?
