C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
My Bonneville Project up date
Old 03-07-2017, 11:58 AM
  #541
Daves obsession
Daves obsession's Avatar
some additional pictures from last year, capturing Corey , and also my racing partner Rick Hardens 883 twin turbo C-4
Classic Corey
Both Cars in line at sun sup
out the back of our pits at sunrise
BV85 (03-17-2017)
Old 03-07-2017, 12:02 PM
  #542
Black 03 Z06
Black 03 Z06's Avatar
Just have to get there, beautiful pictures.
Thank you.
Old 03-09-2017, 01:41 PM
  #543
A26B
A26B's Avatar
Originally Posted by Daves obsession
Time to update the progress of the Beast: we are prepping for the 2017 speedweek Aug 12-19. Last year we had horrible conditions with the car never being able to complete the course as it got loose in the 3-4 mile section resulting in sideways chute pulls at 225 mph. Very exciting to say the least. But it is clearly evident that the hp is there for a record if we can stay hooked up.
Currently working on a prototype of a larger throttle body in the hope of a few more hp.
Oh and a big shout out to Jerrys Gaskets, we lost a freeze plug out the back of one of the heads during a run, the motor got smoking hot but the Head gaskets held!!
Dave
Hi Dave,
Thanks for the head gasket comments. Hearing feedback is great, but at your level of exotic engineering and sustained high rpm, topped off with a overheated engine its the ultimate confirmation. I'm proud to be a small part of the quest. You've got a great team & I know this year will be the record you all have worked so hard for (Lord willin' & the creeks don't rise).
Old 03-12-2017, 10:34 PM
  #544
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
We've gotten just under 450" of snow so far this year, at the 'Bird...it all needs to melt into that valley.
It should dry up by mid July though...an fingers crossed for minimal rain for that time frame.
Old 07-17-2017, 06:50 PM
  #545
Daves obsession
Well time to update this thread, as we are now ready to get back on the salt for speed week August 10-17. This years improvements are a one off single blade throttle body at 68mm and more Hp on Corey's tune. In addition we hope to have better flow dynamics and the possibility of a small increase in boost at top speed.
Old 07-17-2017, 07:09 PM
  #546
Daves obsession
This is the critter😀
Old 07-17-2017, 07:26 PM
  #547
Daves obsession
View from a air molecules point of view
1993C4LT1 (07-17-2017)
Old 07-17-2017, 10:34 PM
  #548
1993C4LT1
1993C4LT1's Avatar
Whoa
Old 07-18-2017, 07:32 PM
  #549
XLR8TIN
XLR8TIN's Avatar
that should grab some air
Old 07-19-2017, 10:11 PM
  #550
Daves obsession
I hope it does as the 372 cubic inches moving up and down at 8200 rpm moves a lot of air thru custom cams, ported heads, 2 inch primary's, 3 1/2 collector, 4 inch x pipe twin 4 inch ovals to the back of the car, so I expect 1 psi of boost at 230 mph whould be a good thing, as the best we saw with the old set up was 1/2 psi at best.
Old 07-20-2017, 08:16 PM
  #551
tpepmeie
tpepmeie's Avatar
Dave,
please strap a Go Pro on that thing and stream your adventure live! I'd love to be there, but not this year. Hope the cams give you that extra HP to break the record.
Todd
Old 07-21-2017, 12:21 PM
  #552
Daves obsession
From a few years back, mid 225 mph run. Shows how long it takes for the safety guy to show up, and then eventually the push truck and crew chief.
Old 07-21-2017, 07:15 PM
  #553
XLR8TIN
XLR8TIN's Avatar
Record Holder at Bonneville. the goal, WOW! how Great would that be, Good Luck!
Daves obsession (07-21-2017)
Old 08-21-2017, 09:12 AM
  #554
Daves obsession
no record this year, the salt just would not hold much hp, I had the car as heavy as ever, engine ran great,
95ZR1 (08-21-2017)
Old 08-21-2017, 10:18 AM
  #555
dclafleur
dclafleur's Avatar
https://youtu.be/c-iYHc1-sMg
Good to hear the car was sorted well, conditions are sort of a game of luck.
Old 08-21-2017, 07:57 PM
  #556
95ZR1
95ZR1's Avatar
So what was your speed this year?
Old 08-21-2017, 09:50 PM
  #557
XLR8TIN
XLR8TIN's Avatar
Looked like the car went straight without much driver input, sounds awesome, stick with it, you can do it
To My Bonneville Project up date
Old 08-21-2017, 11:32 PM
  #558
Daves obsession
best I could do was 212 at mile 2 then peddled to 200 and back to 212 out the 5 mile, This video will show you how loose the track was in the middle.
Old 08-24-2017, 06:53 PM
  #559
XLR8TIN
XLR8TIN's Avatar
https://www.corvetteforum.com/how-to...stest-corvette
Daves obsession (08-26-2017)
Old 08-27-2017, 04:35 PM
  #560
Zrxmax
Zrxmax's Avatar
If 1 psi of boost is generated by the new design does that equate to about 40 to 50 hp at or near the top speed you will reach?
Regardless... it is super cool to see these pictures and videos of this car reaching for the record! Thanks !
Quick Reply: My Bonneville Project up date
