is a procharger actually just a belt driven turbo charger?
Old 10-09-2010, 12:13 AM
Lil Blue Coupe
Lil Blue Coupe's Avatar
Default is a procharger actually just a belt driven turbo charger?
Please... no laughing (or snickerin).... and forgive the rookie question but… is a procharger actually just a belt driven turbo charger?
I'm asking the question because I have these ongoing conversations with a guy at work that is from the “turbo only” school of thought about how someday I am going to install a super charger on the Vette and he always steers me towards the turbo technology, which I am convinced of now to be quite impressive and not to be poo-poo’d… but told me today he ‘approved’ of my plans because a procharger is actually a belt driven turbo charger… now I’m confused
Can anyone elaborate?
Old 10-09-2010, 12:24 AM
Corvette-Chris
Corvette-Chris's Avatar
St. Jude Donor '08
Or is a Turbocharger just a exhaust driven supercharger?
Seriously, each unit is basically differentiated by the method it creates compressed air. Obviously, you know that a supercharger is belt driven and a turbo is powered by exhaust so I think your buddy's statement is invalid and should ask him what i posted above.
Im sure more technical responses will ensue......
Old 10-09-2010, 12:26 AM
bcarp
bcarp's Avatar
Old 10-09-2010, 12:55 AM
Milan
Milan's Avatar
He must be an import/4 banger guy....
In the import world...the only way to make power is with a turbocharger. Us V8 guys are lucky because virtually everything makes great power for us
To answer your question...your friend is a moron
Old 10-09-2010, 11:39 AM
RIKKITIK
RIKKITIK's Avatar
St. Jude Donor '09
Yeah I know, it's a curse.
Exactly. They are generic current terms. At one time "turbos" were known as "Turbo-superchargers". Both are forced induction, both achieve higher than atmospheric cylinder pressure when the valves close (supercharging). A turbo derives it's name from being turbine driven, by expanding exhaust gases. The name "Supercharger" is commonly reserved for those that are mechanically driven whether centri or roots style (positive displacement) forced induction units. But both are in-fact "Superchargers"
Old 10-09-2010, 01:31 PM
Lil Blue Coupe
sooo... would this be a true statement then?
whether it's an exhaust, belt or mechanically driven charger, they are all super chargers
-M
Old 10-09-2010, 02:03 PM
RIKKITIK
RIKKITIK's Avatar
St. Jude Donor '09
Yes
Old 10-09-2010, 02:20 PM
Its Bruce
Its Bruce's Avatar
http://auto.howstuffworks.com/turbo.htm
http://auto.howstuffworks.com/supercharger.htm
Old 10-09-2010, 02:27 PM
RIKKITIK
RIKKITIK's Avatar
St. Jude Donor '09
And Wiki;
A turbocharger, or turbo, is a gas compressor that is used for forced induction of an internal combustion engine. A form of supercharger, the turbocharger increases the density of air entering the engine to create more power. A turbocharger has the compressor powered by a turbine which is driven by the engine's own exhaust gases rather than direct mechanical drive. This allows a turbocharger to achieve a higher degree of efficiency than other types of forced induction compressors which are more vulnerable to parasitic loss.
Early manufacturers of turbochargers referred to them as "turbosuperchargers". A supercharger is an air compressor used for forced induction of an engine. Logically then, adding a turbine to turn the supercharger would yield a "turbosupercharger". However, the term was soon shortened to "turbocharger". This is now a source of confusion, as the term "turbosupercharged" is sometimes used to refer to an engine that uses both a crankshaft-driven supercharger and an exhaust-driven turbocharger, often referred to as twincharging.
Old 10-09-2010, 04:56 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
I disagree.
If his friend said a Maggie (roots blower for the OP) was a turbo driven by a belt, I would agree with you that he's an idiot, but the compressor wheel and volute on the centrifugals is the same as you will find on the turbos, so it truly is the equivalent of the compressor side from a rather large turbo but is gear and belt driven.
Old 10-09-2010, 05:23 PM
TRIZ
TRIZ's Avatar
Originally Posted by BLOWNBLUEZ06
I disagree.
Well Said.
Old 10-13-2010, 10:54 AM
robert21122
robert21122's Avatar
a procharger is like a turbo that is belt driven just like a vortec or paxton supercharger but since it doesnt run on exhaust its a supercharger
Old 07-17-2017, 02:21 AM
Ryan Martin
1st Gear
Ryan Martin's Avatar
Default The difference
To help OP, a turbo crates more boost, but takes longer to build the boost. A super charger, which was the first booster created, creates less boost per volume, but builds boost faster, and more bottom end torque.
Old 07-17-2017, 12:45 PM
Turpid porpoise
Turpid porpoise's Avatar
So wrong it hurts....
Old 07-17-2017, 05:56 PM
stevieturbo
stevieturbo's Avatar
To resurrect a 7 year old thread ot post utter nonsense...must be a spambot.
Old 07-18-2017, 07:35 AM
Turpid porpoise
Good call, didn't even notice the dates on the posts prior to his.
Old 07-18-2017, 04:27 PM
SBCGENII
SBCGENII's Avatar
Omg it's the fireball Camaro dude from street outlaws!!!
Old 07-18-2017, 08:01 PM
HardcoreABN
HardcoreABN's Avatar
somehow I highly doubt it
To is a procharger actually just a belt driven turbo charger?
Quick Reply: is a procharger actually just a belt driven turbo charger?
