Fuel injector cleaner
Old 10-16-2007, 01:25 PM
JUS 1 MO
JUS 1 MO's Avatar
Default Fuel injector cleaner
Does anyone use a fuel injector cleaner? Such as the Lucas Oil fuel injector cleaner. I have used the Lucas brand for years in my other vehicles, at each oil change..
Old 10-16-2007, 01:39 PM
KrnrKick
KrnrKick's Avatar
I use Chevron Techron Plus every couple thousand miles
Old 10-16-2007, 01:42 PM
moserbe
Support Corvetteforum!
moserbe's Avatar
I have seen that at WalMart. I need to put some in my gas tank, thanks for reminding me.
Old 10-16-2007, 01:43 PM
jbauch357
jbauch357's Avatar
same here, dump in a bottle about the same time as I change my oil...
Old 10-16-2007, 02:08 PM
JUS 1 MO
JUS 1 MO's Avatar
What does the Chevron Techron Plus have that the others don't? Is it better than most?
Old 10-16-2007, 03:22 PM
DeeGee
DeeGee's Avatar
Not sure but if you ever have a fuel gage problem it's the best cure without doubt.
Old 10-16-2007, 03:33 PM
00 Rooster
00 Rooster's Avatar
St. Jude Donor '08
As an alternative to fuel injector cleaner, I am going to use some Seafoam. I don't know if you are interested but here are some instructions: http://forums.corvetteforum.com/show...hlight=seafoam
I am going to do this proceedure but you can also just pour it into the gas tank.
Just something for you to consider.
Old 10-16-2007, 05:55 PM
Big Red Machine
Big Red Machine's Avatar
Default First of all, I'm not advocating you do this to your car!
I personally use a gallon of "Toulene", (I buy it at any paint store for around $12), once a year, mixed with 4 gallons of gas. I've been doing this since 97' on all of my fuel injected cars, it works great on my cars, & in my opinion, does the same job as the $100 fuel injector cleaning service at the dealerships. I think I know what you may be thinking; it's a Dangerous chemical, well yes it is, so I wear rubber gloves, & pour it thru a funnel to keep it off the paint, & try not to breathe the vapors. Not to mention, storing it safely & correctly. Please don't try this just because I do this to my own cars & say it works for me, especially if you have any doubts about this chemical & what it can or can't do, as I really don't want any body coming back on me.
Old 10-16-2007, 07:13 PM
VetteCrazyRichard
VetteCrazyRichard's Avatar
An engineer working at Southwest Research, who tests oils/additives said that Techron was the best. Lucas was "old technology". I've been using it every two months and seems to help the car run well.
Old 10-16-2007, 07:40 PM
Gideon's_Test
Gideon's_Test's Avatar
I use BG44K...Works better than Techron (I've used both, back to back). Not saying Techron is bad, however..
Old 10-16-2007, 09:06 PM
0TheRadioFlyer97
Former Vendor
TheRadioFlyer97's Avatar
St. Jude Donor '08
I use seafoam now. I also reccomend Lucas and Slick 50. Just be sure not to run it too often or it will destroy your fuel regulator.
Old 10-16-2007, 11:13 PM
Yello95
Yello95's Avatar
Received 1,227 Likes on 874 Posts
St. Jude Donor '11
...I have been preaching about 44K for a long time but noone seems to be interested ...I also use Chevron premium gas which has Techron in it so I have the best of both worlds
Old 10-17-2007, 03:02 PM
vetdude
vetdude's Avatar
Use Techron Fuel System Cleaner, not the Fuel Injector Cleaner, for best results. Also, if you have Chevron or Texaco (bought by Chevron) gas stations nearby, the premium fuel contains Techron. Finally, Techron is recommended by BMW and Mercedes for use in their cars so it can't be too shabby.
Old 10-17-2007, 03:39 PM
LRD VDR
LRD VDR's Avatar
Also use Redline SI 1.
Shahram
Old 10-17-2007, 03:42 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Shahram
I put 3 1/2oz in every tankful and a full bottle at oil change time.
Old 10-17-2007, 03:55 PM
99 vett babycar
99 vett babycar's Avatar
Shahram
To Fuel injector cleaner
Quick Reply: Fuel injector cleaner
