Automatic Climate Control Issues
My 2000 automatic climate control is acting erratically. When I push the "Auto" button the a/c fails to come on (outside temp 98 degrees). I can turn on the a/c manually and adjust the fan speed etc. I've checked the dic, and there are no codes set in the HVAC module. Any hints on where to start looking? The temp. lcd is normal brightness.
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Could be a controller fault (that is the head unit there). Does it get really cold when you manually turn it on?
Took a quick scan of the FSM, the Scan tool can detect whether the AC Mode button is working. On provides a path to ground.
It seems to get just as cold (manually) but the temp. **** won't increase from 60-61 degrees (ambient temp is around 96-100 degrees. I' don't think I've ever tried to increase the temp. when it's that hot outside, but I'd think you should be able to set it at 70 or so.
Another vote for the HVAC controller
I'm not sure how much a new unit would cost but I suspect it would be pricey. You could try this CF Vendor that Z06 Jim recommended. He may find you a used spare.
http://forums.corvetteforum.com/show...post1562895126
