243 Z06 vs regular 243 heads ??
I just bought a set of New 243 heads off a crate motor LS6. How can you tell if the valves are the sodium filled or regular valves?? It does have the yellow springs if that helps?
Thanks for the help
Thanks for the help
if they came of a LS6 motor they are the titanium intake valves and sodium exhuast valves. If the heads came off an LS2 motor they are Stainless Steel valves
YEs the Yellow springs are the LS6 heads
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The LS6 did not use titanium valves.
They are hollow stem stainless valves...the intake valves were kept hollow, the exhaust valves were filled with potassium/sodium to better absorb the more intense heat that valve is exposed to.
